Anyone come up with a driver for the hubspace wifi lights?
https://www.homedepot.com/p/Commercial-Electric-4-in-Smart-Hubspace-Selectable-CCT-Ultra-Slim-Integrated-LED-Recessed-Light-Kit-50291/313556956
What kind of API does it have?
No idea but I found this for Homeassistant. Not sure if that will help.
Looks like that makes some kind of connection to the manufacturer’s cloud. So in theory it’s probably possible to write a Hubitat driver for that too.
However I would strongly suggest not using a light fixture that needs an active internet connection and a functioning cloud server maintained by the manufacturer in order to actually work as a “smart” device.
Yes I saw that. Might have to rethink using this type of light.
I have similar canless lights like that, but they’re just dumb old lights. I use a Lutron system to smarten them up, which integrates beautifully with Hubitat over a local Telnet connection.
I need a 4” can RGBW solution.
That does narrow down the options.
What are your goals for color-changing light effects?
It is a light for a niche in our hallway. Need color options for Halloween and Christmas. White for the rest of the year. Don't really need effects but a fade between a couple of color would be nice. I can't use LED strips. So, need a 4" can light or a bulb for a can fixture. I might have to go with a wiz bulb and change out my fixture.
Maybe this one? Uses zigbee.
