Why do I have this constant "spray" of these notifications?
What happens if I issue a command, and it's between enabled and disabled?
With all three of my hubs sitting right next to each other, on the same Lan, plugged into adjacent ports in the router, why am I getting these constantly? (It can't be a hickup on one and the others).
Please note: all three of my hubs are running the exact same level, they are all running UDP synch every 2 minutes. Why is this happening?
Switch them all to TCP. Seems UDP is being spotty
Also pop up when you restart a hub too.
It seems (so far) to have gone away by switching from UDP to TCP.
I wonder if that will affect the sync time?
Will they still remain in sync, as fast?
I will try it and see...
Thanks for the suggestion.
I'm having the same issue. When attempting to change to TCP I got the warning all devices would be disconnected. I don't have time tonight to deal with an issue but wondering if they automatically reconnect after the protocol is changed on all hubs.
They did all disconnect, and showed up as "OFFLINE", but that corrected itself after a while.
It shouldn't affect speed.
Where/how do you do this?
Did this option (select udp or tcp for hub mesh) get moved? Or deprecated? I recall seeing it but I can no longer find it.
Yeah, that is what I remember. A couple of major revisions back that option was dropped.
HubMesh is TCP only now.
Thank you!
