Correct here are links:
Thank you both
@aaiyar @ogiewon
So here's a for instance that I don't understand. I hit my Zooz remote switch that sent the command to turn on several lights. This couch light took longer than any of the others in the command. I also never physically hit the switch. It's something like this that I just don't know what to do with. Any thoughts?
dev:362021-03-16 07:58:08.389 pm infoRemote Switch - Living Lights button 1 pushed
dev:412021-03-16 07:58:28.851 pm infoCouch Light Switch was set to 75% [physical]
dev:412021-03-16 07:58:13.535 pm infoCouch Light Switch was set to 4% [digital]
dev:412021-03-16 07:58:13.533 pm infoCouch Light Switch was turned on [digital]
It would really help immensely if you could share all of the details of your devices (brands and model numbers) so that the community can provide you with much more meaningful suggestions. For example, you've mentioned a Zooz remote switch above, which is supposed to control several lights...right? What App are you using to perform that automation (please share a screen shot)? Also, what type of lights are they? Zigbee, Z-Wave, Philips Hue bridge attached, WiFi? There are just so many possible permutations of end-user systems that it is very difficult to assist with so little information. Help us help you, please. We're data junkies and need lots of information to formulate a hypothesis of what the problems might be.
I can help with Zigbee and Lutron Caseta devices, as well as things like Alexa, MakerAPI, Geofencing, etc... But Z-Wave is not my strong point, as I am not using it any longer. But other are and have good luck with it. However, there are many old Z-Wave devices that just don't work well at all with the Hubitat C7's 700-series Z-Wave chip. This is due mainly in part to the firmware that is supplied for that 700-series chip, from its vendor...not due to Hubitat's code. The old SmartThings hubs used a 500-series Z-Wave radio, which behaved differently than the new 700-series radio. Many of the Z-Wave issues with the 700 series radio seem to be caused by devices being paired with S0 security, which can bring a Z-Wave network to its knees. Also, energy/power reporting Z-Wave switches and outlets are also know to flood the Z-Wave network and cause massive slow-downs. Some devices need their own firmware updated to work reliably with Hubitat. Yea, I know I said I don't know too much about Z-Wave...but this is just information I have gleaned by reading other community members' posts over the past few years.
Thank you I will try and be more specific. I know you said Z-Wave isn't your think (even thought you're right you know a great deal!) I thought I would still provide as much information as possible. Though it just sounds like my problem is like you said, so many legacy devices.
I have a Zooz 700 Series Z-Wave Plus Mesh Network Remote Control & Scene Controller ZEN34. I'm using Rule Machine which can be seen here.
The Couch light is a JAS12724 - GE 12724 Z-Wave(R) in-Wall CFL-LED Dimmer Switch. It is my only switch that uses a neutral because I ran this one myself.
The TV Light is a GE Z-Wave Wireless Smart Lighting Control Lamp Module, Dimmer 12718
And the End table light is a Philips Hue.
My Hue is connected via LAN and is in the same network switch as the Hubitat.
Is this the sum total of your z-wave devices? I ask because the Zen34 isn't a repeater. So depending on the geometry of your house, and the materials of construction, signal propagation can be a real issue.
Z-wave networks are most responsive when there's a strong mesh with multiple repeaters available.
This document might help:
https://docs.hubitat.com/index.php?title=How_to_Build_a_Solid_Z-Wave_Mesh
So, as a quick test...what happens if you remove the two GE Z-Wave devices from the rule temporarily, and just have the Zooz Remote as the trigger to turn on the Philips Hue light?
I am curious to see if your problem is really a Z-Wave mesh network issue. The two GE devices you have listed are the very old Z-Wave (non-plus) generation of devices that caused me so much grief while I had them. For me, replacing them was the only solution.
If you could show a screen shot of your Settings-> Z-Wave page, which I believe will show all of your Z-Wave devices, their Z-Wave security, and their speed. It may also show if you have any Ghost nodes that need to be removed.
No no those were just the devices involved. I have combinations of battery and AC, but I think I have 1 mostly non Z-Wave Plus devices. Which then begs the question, if everything worked flawlessly with Smart Things(outside of needing the cloud), will I get this to work with the C7 Hub and should I maybe look for a C5? or keep ST?
I have:
- 11 GE/Jasco non neutral switches all over my home.
- 3 Zooz Z-Wave Plus S2 Motion Sensor ZSE18
- 2 Aeotec Smart Dimmer 6
- 1 Aeotec Multisensor 6
- Go Control Garage Door Controller
- 2 Leviton DZPA1-2BW
- 1 Leviton DZ6HD Z-Wave Dimmer
- 3 NonPlus GE Outlets
- 3 GE Z-Wave Wireless Smart Lighting Control Lamp Module, Dimmer 12718
- 2 Kwikset 910 Deadbolts
- 1 GE Z-WAVE PLUG-IN OUTDOOR MODULE
Zigbee
- 4 Smart Things Zigbee Button Switches
- 5 Innr Zigbee Smart Plug
Hue (Plugged in via LAN)
- 23 Hue bulbs of various combinations
- Lutron Aurora Dimmer Switches
I don't see any ghost nodes, which is good. However, the vast majority of your nodes, including the many z-wave+ nodes are all communicating at 40 kbps. A few nodes are communicating at 9.6 kbps, and just a single one at 100 kbps. That isn't so good.
I'm not sure what the solution is. But I'm sure someone more knowledgeable about z-wave will pitch in.
Tagging a few people here in no particular order: @erktrek @JasonJoel @kahn-hubitat @tony.fleisher @lewis.heidrick @thebearmay @bcopeland
I see many non-plus z-wave devices here, which is not ideal, of course, but I understand the issues with older equipment and lacking neutral.
A few question that might help us understand things a little better:
How long since the last hub reboot? (It will help understand context for some of the metrics.)
How long since you last ran network-wide z-wave repair? Have you added non-plus mains powered devices to the hub since then?
Are you running the z-wave poller app? if so, which devices are setup to be polled?
Hi Tony,
Thanks foe reaching out. I’ve had these switches back when Revolv was my hub. I loved that thing.
- Last reboot has been probably about a week or so.
- No non+ mains have been added since then no. They have all been installed for weeks.
- I am running the pollen app on all main switches except the single ZW+ switch I have in my basement.
Honestly it’s almost an argument for me to find a C5 hub no?
No, because that much polling would affect a C-5 just as badly.
What happens to your zen34 remote response times if you turn off polling for 30 minutes?
From my 2 second peek at this - It looks like the large # of S0 devices AND polling is part of what's killing this hub.. If you can't replace a lot of those devices (and I understand completely why not) and you want to stick with the HE echo system then maybe go to a multihub configuration and pair all the S0 devices with no security using a UZB-7 or Z-Stick as a secondary controller.
edit: in fact that's the first thing I would do is change the S0 pairings to no security then see where you are.
+1
I would disable Z-Wave Polling completely, as it is known to bring a Z-Wave network to its knees. I couldn't get my Z-Wave network to be stable and responsive with even just a few old GE non-Plus devices being polled. Combine that with the numerous S0 paired devices, and you have a perfect 'network' storm scenario.
Unfortunately, the 700 series Z-Wave radio's firmware will not pair devices that are capable of using security without any security. Thus, the recommendation by others above to use a 500 Series Z-Wave stick to get these devices re-added to the network without S0 security. Plenty of threads in the community where this is discussed.
I remember this slowng down my hub when I only had 3 non-plus devices. I replaced with zigbee (perhaps like @ogiewon), but before I did that, in order to maintain a reasonable knowledge of the state of those switches, I polled them once every two minutes using rule machine, and did every fifteen seconds when a particular motion sensor was active.
As for your geofencing; the HE app is inconsistent in my experience, but a combination of presence devices and using @jwetzel1492 ‘s combined presence app works every time for me.
If I had to live with polling (couldn't replace devices for whatever reason), I would buy a 2nd hub and put them all on that hub on their own mesh.
Secondly, If I had a lot of S0 only devices I would either buy a C5 hub and put them there or get a zwave stick and pair them w/PC Controller software. I wouldn't put S0 only devices on a C7 hub since SiLabs F'ed up the S0 only device pairing.
@JasonJoel @Ken_Fraleigh @ogiewon @thebearmay @erktrek @aaiyar
For starters I can't thank you all enough for giving me some of your time. It's much appreciated.
My question for the group is it seems like I have a few options but I was feeling like it really boils down to two. Because it sounds like no matter what configuration I try, my legacy ZW devices are going to be causing trouble. Especially with 11+ of them.
So it seems like I have two basic choices more or less:
- Replace all legacy devices with new ZW+ ones.
- Find a C5 Hub.
Would you agree that seems to be more or less where I'm at? I guess there's always just keep my Smart Things up and look into Hubitat for my next home.
Let's break this down a bit. The issue may not be legacy devices. I have loads of them on my C-7 z-wave network, although I'm not using z-wave poller. The issue might be S0 paired devices.
That issue is fixed much cheaper. A UZB7 stick is about $20. PC-Controller is free. And @danabw has written a clear and detailed writeup on how to use PC-Controller along with a Hubitat C-7. I've tagged him here so he can add a link to his writeup.
Edit: Found it. Here's a link to @danabw's writeup. It has everything you need.
