Did all your hubs come back? I updated my static IP hubs to the dreaded .138, and while I was able to get my C-7 back, my C-5 showed up for a little while, but then went "network silent" ever since. It is still running, as my Zigbee and Z-Wave devices are still doing what they're supposed to be doing, but on the network side, totally unresponsive. Tried different subnets, power cycling, all the "finding hubs" procedures including MAC address searches, but no joy. I'd hate to start from scratch, but not sure what to do next.
If you are using hub mesh then settings -> hub mesh will show you the current ip addresses
An excellent idea, and I did try that, but the entry field is blank (where once it was populated).
Do a network reset. Hold the hidden button on the bottom for 7 seconds. That will set it back to dhcp.
Provided there isn't something wrong with the router itself, I would double check your mac address in the table and make sure there are no weird things like spaces. (while spaces should be rejected, I've seen some weird stuff with consumer grade products)
I'm having a slightly different issue. My C7 was using DHCP with a static IP reserved on the DHCP controller. This has been a working configuration for years.
After updating from 134 to 139 (didn't touch 138 at all), my C7 doesn't respond on the ethernet connection. I've tried the 7-second hidden button reset, but it hasn't resolved the issue. I removed the IP reservation in hopes it would pull a new/different IP, no such luck.
findmyhub.hubitat.com "Connect to Hub" doesn't work and still points to the original IP, leading me to believe my C7 isn't connecting over Ethernet at all.
I setup an old router and connected my C7 to that and it still doesn't pull a DHCP address. Tried the 7-sec hidden button again as well and still nothing.
Note: Initially my C7's Z-Wave and Zigbee were semi-functional, i.e. Zigbee motion sensor triggering rule to turn on Z-Wave light switch, after the update's reboot. However, since the initial 7-sec hidden button usage Z-Wave and Zigbee devices in my home are non-responsive leading me to believe my C7's Zig & Z radios are offline now.
A BIG thank you to @jtp10181 as your suggestion was spot on. Pressed the button for 10 seconds while hub was on, then the hub turned blue briefly, then green briefly, then blue again for an extended period, and finally green again, at which point the C-5 hub became discoverable. First action - make a backup. Second action, update to .139. That's probably the closest I've been to bricking a device from a manufacturer firmware update. Again, big thanks to the Community and Jeff Page.
I'm just going to add this note to my experience, in case it helps someone else searching this thread. Regarding the updates, I have 3 C-8 hubs on a different install on a different network. All three were running firmware 2.3.6.146. Two updated without issue. When trying to update the third one, it became unresponsive for long periods of time when clicking the notification in the upper right, and attempting to download a backup. Long periods of time means a half-hour to an hour or more. Here's the weird part. During one of these long periods of unresponsiveness, I ran an instance of AngryIP (v2.21), an IP and Port scanner. The moment AngryIP touched the hub (at xxx.111), the hub became responsive, even before AngryIP had finished outputting the scan results (hub webpage was open in a concurrent browser window). From that point on, not only was the hub responsive, but perhaps even "spritely." Maybe it's because, in contrast, anything would have been "spritely." Anyhow, not sure why, but wanted to put that out there in case it helps anyone else. FWIW.
