I wouldn't do that unless absolutely necessary. That is the nuclear option, you are nowhere near needing that yet.
The other step I would do if you have not done so it to assign Hubitat (and all home automation devices really) a static address in your router. The idea here is that 192.168.0.xxx is always the address of Hubitat, Lutron, Alexa, Hue, or whatever so you and the hub can always find the other devices.
Thanks, it didnt work anyway as it didnt accept my MAC printed on the sticker on the back of the hubitat, Also I have quite a big network and everything is assgined a static IP, I keep record of this in a spreadsheet.
Doing some more reading on the forums I somehow am starting to beleive this might be a network block of some sort but have enabled emergency access in my firewalla gold coniguration for this which means there is no blocks.
I run a firewalla gold as my main router, my cable modem feeds the wan port on the Firewalla gold, one of the lan ports on the firewalla is hooked up a 24 port netgear prosafe managed switch, I have tried the Hubitat hub in one of the spare firewalla ports, So Cable Modem to Wan Port, Lan port 1 to 24 port switch, Lan Port 2 to Hubitat, but still have the same issue.
Be sure that if this continues for much longer to contact support by emailing them. support@hubitat.com
BobbyD is the main support person, so you could also tag him on this thread, but it is usually better to get a trouble ticket open to get a faster response.
Support can see and have you try things that we cannot here in the community.
Thanks Both, I have tried assigning a new LAN IP via my address reservations, the new IP I have assigned in now .61 rather than .75, I have also opened a few port forrwards for the hubitat, Port22, 2604 & 8081 as my Firewallabox can see thats what ports the device has been trying to use, I also enabled UPnP but still no joy, I also tried the http://192.168.25.61/hub/cloud/updateDiagnosticTool but just get a page cannot be displayed prompt.
I also opened a new case - number: 17730, Bobby did reply with some steps to try but had no joy and I believesupport is now closed I think, I am based in the UK so its nearly 11:30PM here.
I believe its 18:23 where support is and they closed @ 18:00 so will just need to wait till tomorrow I think, see what happens.
I know @ogiewon linked to this earlier (and you may have tried it already). However, just for s & g, would you consider turning your firewallabox off and trying it again?
Or is there a way to connect the hub directly instead of through a switch or two? Maybe just enough to get it set up and then put things back to normal.
I have just been away, turned off cable modem for 1 minutes, disconnected power Firewalla Box, Disconnected power to the switch and my WiFi mesh system, powered my PC Down, then powered up the cable modem, then the Firewalla gold router, then my switch then my Wifi Mesh system and finally my PC. Still get page cannot be displayed when trying http://192.168.25.61/hub/cloud/updateDiagnosticTool.
The Firewalla Gold does have 4 LAN ports, 1 for Wan and 3 for additional networks, I did earlier tonight try the Hubitat direct into the Firewalla gold but the same problem was met
Edit: I shoudl also mention the 3 Lan ports are all assigned to the same network as these can be assigned to different LAN's if need be but I dont have them set that way.
Have now also forward port 443 as I can see in the Firewalla Network flows the device is accessing service.cloud.hubitat.com (It's hitting various IP's within 52.84.138.XXX and using random ports to connect on from the local hubitat device) - It seems to be uploading and downloading a few kb's at a time.
Some screenshots:
Thanks have replied to the PM, have a feeliong my Hub is broken, swapped out my Firewall box and have went back to the ISP provided modem\router combo, I have the Hubitat wired into the one of the ethernet ports and a PC and a Phone connected wirelessly.
Still get the exact same issue, cannot load a page on the browser and unable to discover the hub.
Once thing I noticed is that when I check the time on the hub it is saying 2015
And the update time option doesnt seem to work, Really no idea what is going on here and never had a device that has been as troublesome as this, where do we go next @bobbyD
So my new hub turned up today, done the same as last time, hub light went green this time, registered it in the portal without an issue and without any fuss, so happy it is working.
Would also like to thank @bobbyD and the guys at Ultrasmart whom I ordered the hub from for such the quick turn around for the replacement, they also sent me a free complimentary water leak sensor I guess due to the issues I had so can't thank them enough but over the moon now, now to start figuring out the world of hubitat and porting my devices across form smartthings, Thanks guys you get a thumbs up from me
I'm away from home but got the gf to plug in my brand new c7 and it too is sitting on a blue light and she cant get the portal to find it via mdns Mac or ip, have to wait a week until I'm home to see wtf is wrong with a brand new hub, trying to leave smartthings but not a great start, I'm sure with some effort we will get it going eventually.
Mines was down to the hub not beiong formatted correctly and it was not picked up during the QA checks, needed a replacement hub in the end, its worth conacting support for sure as they helped me identify the issue and get a new one sent out swiftly.
If you can get your G\F to conact support and provide the mac ect I am sure they would be more than happy to help, I too also moved over from smart things and I dont regret the move as I no longer have to rely on the cloud and all my autoamtion's work all of the time.
Hello, I see I was way way off on my advice, but glad to see Bobby got it sorted out for you.
I just got the chops to finally fire up my C7, as after seeing your predicament I thought I shouldn't wait any longer in case of issues. Happy to report mine fired right up
