I have netatmo and it is nice to bring over the sensors... as a bit of a micro-weather geek, I have the Wind Gauge and Rain Sensor.
Would you please enable the Hublink to capture and push these values over to the Hubitat Virtual Omnipresence sensor?
What capabilities do they use in ST?
So, they should be showing up in the Send Hub Events app to be selected, right? But not doing anything on the Hubitat side.
That is correct
Here is a rain sensor… I don’t quite understand the steps to make it virtual
* http://www.hubitat.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Based on Brian Steere's netatmo-rain DTH
metadata {
definition (name: "Netatmo Rain", namespace: "cscheiene", author: "Brian Steere,cscheiene") {
capability "Sensor"
capability "Battery"
capability "Refresh"
attribute "rain", "number"
attribute "rainSumHour", "number"
attribute "rainSumDay", "number"
attribute "units", "string"
attribute "lastupdate", "string"
command "poll"
simulator {
// TODO: define status and reply messages here
preferences {
input title: "Settings", description: "To change units and time format, go to the Netatmo Connect App", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input title: "Information", description: "Your Netatmo station updates the Netatmo servers approximately every 10 minutes. The Netatmo Connect app polls these servers every 5 minutes. If the time of last update is equal to or less than 10 minutes, pressing the refresh button will have no effect", displayDuringSetup: false, type: "paragraph", element: "paragraph"
tiles (scale: 2) {
multiAttributeTile(name:"main", type:"generic", width:6, height:4) {
tileAttribute("rainUnits", key: "PRIMARY_CONTROL") {
attributeState "default",label:'${currentValue}', icon:"st.Weather.weather12", backgroundColor:"#00a0dc"
tileAttribute ("rainSumHourUnits", key: "SECONDARY_CONTROL") {
attributeState "default", label:'Last Hour: ${currentValue}'
valueTile("rainSumDay", "device.rainSumDayUnits", width: 4, height: 1, inactiveLabel: false) {
state "default", label:'Total Day: ${currentValue}'
valueTile("units", "units", width: 2, height: 1, inactiveLabel: false) {
state "default", label:'Units: ${currentValue}'
valueTile("battery", "device.battery", inactiveLabel: false, width: 2, height: 2) {
state "battery_percent", label:'Battery: ${currentValue}%', backgroundColors:[
[value: 20, color: "#ff0000"],
[value: 35, color: "#fd4e3a"],
[value: 50, color: "#fda63a"],
[value: 60, color: "#fdeb3a"],
[value: 75, color: "#d4fd3a"],
[value: 90, color: "#7cfd3a"],
[value: 99, color: "#55fd3a"]
valueTile("rain", "device.rain") {
state "rain",label:'${currentValue}', icon:"st.Weather.weather12", backgroundColor:"#00a0dc"
valueTile("lastupdate", "lastupdate", width: 4, height: 1, inactiveLabel: false) {
state "default", label:"Last updated: " + '${currentValue}'
standardTile("refresh", "device.refresh", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
main (["main"])
details(["main", "rainSumDay", "battery", "lastupdate" ,"refresh"])
// parse events into attributes
log.debug "Parsing '${description}'"
def poll() {
log.debug "Polling"
parent.poll()
def refresh() {
log.debug "Refreshing"
parent.poll()
Wind sensor…
* netatmo-windmodule Date: 05.08.2017
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Based on Brian Steere's netatmo-basesatation handler
metadata {
definition (name: "Netatmo Wind", namespace: "cscheiene", author: "Brian Steere, cscheiene") {
capability "Sensor"
attribute "WindStrength", "number"
attribute "WindAngle", "number"
attribute "GustStrength", "number"
attribute "GustAngle", "number"
attribute "max_wind_str", "number"
attribute "date_max_wind_str", "string"
command "poll"
simulator {
preferences {
tiles (scale: 2) {
tileAttribute("WindStrengthUnits", key: "PRIMARY_CONTROL") {
attributeState "default", label:'${currentValue}', icon:"st.Weather.weather1", backgroundColor:"#00a0dc"
tileAttribute ("WindDirection", key: "SECONDARY_CONTROL") {
attributeState "WindDirection", label:'Direction: ${currentValue}'
valueTile("GustStrength", "device.GustStrengthUnits", width: 2, height: 1, inactiveLabel: false) {
state "default", label:'Gust: ${currentValue}'
valueTile("GustDirection", "device.GustDirection", width: 2, height: 1, inactiveLabel: false) {
state "default", label:'${currentValue}'
valueTile("max_wind_str", "device.max_wind_strUnits", width: 2, height: 1, inactiveLabel: false) {
state "default", label:'Max: ${currentValue}'
valueTile("units", "device.units", width: 4, height: 1, inactiveLabel: false) {
valueTile("WindStrength", "device.WindStrength") {
state "WindStrength",label:'${currentValue}', icon:"st.Weather.weather1", backgroundColor:"#00a0dc"
valueTile("date_max_wind_str", "date_max_wind_str", width: 2, height: 1, inactiveLabel: false) {
valueTile("WindAngletext", "WindAngletext", width: 2, height: 1, inactiveLabel: false) {
main (["main"])
details(["main", "GustStrength", "GustDirection","battery", "max_wind_str","date_max_wind_str" ,"lastupdate","refresh"])
def poll() {
log.debug "Polling"
parent.poll()
def refresh() {
parent.poll()
Anything regarding this?
This is not on our list as it’s a total custom device. Is there some reason you can’t move the device itself to Hubitat, as opposed to wanting to send events from ST?
These are netatmo devices and hubitat does not support netatmo. However, ST does so I can see information in ST but cannot see the information in hubitat (but can see the device).
Hubitat … Is there any chance your Hub Link app code (for Hubitat) could be published somewhere e.g. GitHub ? Such examples are really useful and instructive and assist in our differing transition needs
I have the NetAtmo (Connect) on my list to port over sometime this summer or early fall along with its device code.
So good news, here is the thread With a working integration. Here are, however, the issues with the working integration that of been discovered this far. Perhaps you can help?
Although all of the device types have capabilities for measurements such as rainSum , CO2 level, wind speed etc... Habitat has yet to implement these measurement tools as conditions and/or triggers for rule machine. So at this point in time all of this data is nothing more then something to look at, rather than something to act upon. For instance, it is impossible to trigger an automation if it starts raining outside and your Netatmo device detects rain.
It has been noted by support that this particular implementation may cause the scheduler to actually crash with respect to other rules within Rule machine simple lighting and other automations from Hubitwt. A recent firmware update should’ve fix the scheduler issue, however it does allude to the fact that this particular device probably still needs a little bit of polishing
