Hubitat® Safety Monitor
Hubitat Safety Monitor will not let me setup a pin code for iris 3405-L
can anyone help step up Hubitat Safety Monitor?
You don't need HSM to set up a pin for the 3405....
That said, go to yourhubip>>apps>>add built in apps and pick HSM..
I have it install but keypad does not arm/disarm.
You can write a rule in RM to do so... But as I said, you can go to yourhubip>>apps>>add built in apps and pick HSM
If I recall correctly, Hubitat Safety Monitor isn’t where you would create a code for your Iris keypad.
You can do that on the device’s settings page, or with the Hubitat app named Lock Code Manager.
Once the code has been stored in the keypad, you can configure HSM to make use of it.
HSM to make use of it to arm/disarm the arm.+
