I just bought a hubitat hub and I worked fine the first 2 days, after that it suddenly turned off and never turned on again, I have tried other cords and 5v chargers but is not working anymore
Any lights on the hub? Or none?
If there are no lights on, and you replaced the power supply cord, you probably should email support at support@hubitat.com and get a trouble ticket started. I am also going to tag @bobbyD here.
No lights at all, and not found in network. It was working fine last night.
I agree with @neonturbo, if youโve ruled out both the power supply and usb cable, itโs likely an issue that only support can help with.
Where did you purchase the hub?
