So I moved the hub outside. It’s a mere couple feet from the switch perfect line of sight. It acts no different. I excluded and re included. All the same results. I moved it back inside to its normal spot and I can perform the same exclusion/inclusion. There has to be something I am missing. Also I see no configure in the settings…
Another thing I have noticed. I can push the off in the app, I go to logs and it shows it as an on command.
One more thing to note.
Now when I press the override button on the switch itself, it’s always an “on” command, no off.
Thanks for all the help. /sarcasm
Into the trash this goes. Products aren’t worth anything if there is no support.
