Ah yes the good old WAF (Wife Approval Factor). I have found a good balance of WAF focused automations keep her onboard. SHMBO most enjoys...
Closet strip lights activated by contact sensor
"Laundry done" notification sent to SMS and Echo dots
Garage door opener automated on presence detection.
Another new Hubitat user here from Wink. I'm glad I found this thread because this problem was driving me crazy. My local dashboards were loading through the Android app but very slowly (15-20 secs) compared to loading in Chrome on the same phone.
It is fixed in the beta release and the dashboards in-app are now loading as quickly as in Chrome (1-2 secs).
I have had the same issues as described above. My wife and I both have Pixel 3a phones and neither one will load the dashboard when on the same WiFi as the hub. When I try to select the hub again through settings I tells me that the hub is not available / unresponsive despite being able to access it without issues with my Windows 10 computers.
Sorry to res what seems to be a very old thread, but I've got this issue and so I'm wondering if this hasn't been patched still?
I can access the dashboard outside of my local network, but not when inside it. It also looks like you can switch Wi-Fi back on whilst you're in the dashboard display, and it'll carry on working for a while even if you close the app and re-open it.
Anyone got a solution to this? It was May 2020 that the beta was released that fixes this issue, I'm presuming that version is mainstream by now but I have this exact issue. The dashboard won't load if I'm on the local network, but if I get off the WiFi or select the hub in settings and go back, the dashboard works fine.
I don't think this is very common, nor do I think that this issue is the same cause as way back in 2020. There have been numerous updates to the hub since that time, so it would be unusual for a bug to have gone unnoticed or not fixed for nearly 3 years.
Can you check these settings in the Advanced section of the Dashboard app in the Apps tab (on the hub, not the mobile app) and see that they are set like this:
I have not had this issue since the update in 2020. The advice above would be a good place to start. Please report back if it doesn't correct the problem.
I have this issue as well. Does not load when I'm on my home WiFi network, but does when I'm on mobile. I'm new to Hubitat and have two dashboards so far. Both have those "Allow Access..." settings enabled.
I just experienced this after the latest update and modification to the dashboard.
Click on Settings COG in the bottom right, click on the HUB you want to operate then click on the DEVICE you want to use. It will re-attach your system to the app.
My dashboard settings are definitely set up to allow access remotely and locally. I have double checked this but also the fact that it sometimes works (as per the above workarounds) also shows this.
However, new weird behaviour....it started working normally about 2 weeks ago and I thought it had been fixed, but now my dashboard has completely disappeared from the mobile app now. It's still present in the Hub web page and I can still access it there, it's just no longer listed in the app. Logging out and back in, or selecting the hub in the app no longer functions as a workaround.
The only way I could get around it this time was to switch in the settings of the app "enable customer dashboard". Once I switched this, the dashboard appeared again and appears to be working normally
