Hubitat mesh linked devices offline(solved by reboot)
I connected my C-8 and C-7 via the Hub Mesh and was initially able to share certain devices. A few days later it stopped working and now all linked/shared devices are showing offline. Both hubs have the same update and connected to ethernet. The devices do not appear as offline in the hub they are actually connected to. Any idea as to what is causing this?
Have you updated the hubs, recently? It could happen that after updating both hubs at the same time, one reboots faster than the other. This can be corrected by rebooting the hub(s) again. Go to Settings and select Reboot Hub. See if that fixes the problem.
That appears to have resolved the issue. Thank you!
