Hubitat integration with Bond Pro - for Fans ... Fans not found
Friends, I installed Bond Pro tonight to be able to program my fans. I successfully installed the Bond Pro. I successfully used the Bond Pro integration app. I then successfully added a fan to my Bond app on my iphone. I hit refresh on the bond integration app.
However, I am not able to see the fan I added anywhere within Hubitat (not as an app, not as a device, etc.).
I would be grateful if someone could help me get over the hump.
Many thanks.
In the bond app you should have something like this which shows the linked Bond Hub which you can click on.
That goes to the Hub "device" which at the bottom you will have child devices for each fan/light.
In the devices list it will look something like this:
Many thanks. I found it, and am set. I appreciate your support.
