Hubitat Installed, But Can't Do Anything
After discovering my hub on the network, logging in, registering the device and updating the firmware, I can't go anywhere from the main screen. When I mouse over settings, for example, I see the target link is:
http://192.168.1.101/hub/edit
however, when I click any menu option I always end up at:
http://192.168.1.101/#TOS
I'm stuck at the welcome screen with various cards, Group Devices, View Devices, etc. Can't get to settings or anywhere else. Using Chrome for a browser.
I have seen that happen once or twice, but not sure why. Our engineers are looking into it. Meanwhile, go to the following page directly:
http://hubs.ip.address.here/hub/acceptTOS, and it should work fine going forward.
(replace hubs.ip.address.here with actual IP address for your hub)
Here's a link to a video of what is happening. When I clicked your link @bobbyD I just got Page Cannot Be Displayed. Edit, I just noticed your message to replace the IP address section. Oops!
That took me to a white screen where I couldn't do anything, however I did go to the main page manually and now I can navigate. Thanks!
Best thing to do now is update to the latest platform, then update your z-wave stack )You will see the button on settings>>z-wave details at the top. Once it's updated it will disappear.
Also please read this, especially the z-wave section
As per my original post, I already updated the firmware. The only thing I added for devices, after everything was working, is 2 ZigBee Door Contact Switches.
Right but I posted that for rules of thumb going forward.
Actually, that is not the button users should be looking for, when updating the firmware.
The one above is to update Z-Wave Settings, not the firmware. If an update is available, the button will state clearly: "Firmware Update". Absence of the Firmware Update button means that hub has already been updated.
ef609d42fbb1ee9640c4462a4911bae8db97752e_2_690x300
NOTE this will be more clear in the next release, when the Update button will change to Save, to limit this confusion.
