Hubitat-IFTTT-Arlo
I have 2 virtual switches controlled by a rule which is working fine to fire an applet in IFTTT, to arm or disarm my Arlo cams.
This has been working fine for a while, but this mornings its consistently failing. I've checked/re-authorized both accounts In IFTTT with no improvement. Any ideas?
Did the IP address to your hub change? Can you access any cloud dashboards on your hub?
I've used IFTTT a lot. If something like this happens, sometimes the only thing to do is remove the service and the applets and then re-add them. Especially if the IP of your hub changed...IFTTT does not handle some changes well at all.
Rebooted hub, router and edited/saved the apps in IFTTT and all working now...Cheers
Glad it's working for you now. I use the same setup with my Arlo cameras however I only use one virtual switch When it turns on the Arlo cameras are armed via IFTTT then when it turns off they are disarmed via IFTTT. Might simplify your setup a little.
Thanks for the tip, I'll do that :slight_smile:
