Hubitat Hub: 220 volt
A quick question.
Can I take a hub that has been made for North American voltage, and use it in a 220v country (with just an adapter)? Or, do I need to stick it on a voltage converter (from 110 to 220)?
The hub is powered by 5V usb.
Use a usb charger rated for wherever youโ€™ll be plugging the hub in, and the hub wonโ€™t know the difference.
Also consider whether the hub contains the appropriate radio(s) for that country's assigned Z-Wave, etc. frequencies. See Z-Wave Global Regions - Silicon Labs
Plus, look at your present adapter. It might be good to go.
Yes many chargers are dual voltage, of course you might need a prong adapter
