I am getting my hubitat delivered tomorrow. Until now, I’ve used Google home and had minimal smart home devices.
I recently installed some Mysa baseboard thermostats, which are wifi and work with all the major players including HomeKit:
Certainly the local control within HomeKit is appealing. But I also don’t have a HomeKit hub yet.
Looking at the hubitat+HomeKit integration it pretty clearly points out:
NOTE: This integration is one-way: Hubitat devices can be shared with HomeKit. This does not allow for direct integration of HomeKit-only devices into Hubitat.
So does this mean I will not be able to have local control of my thermostats, and might as well just continue to have it added to my Google home and exposed to hubitat that way, where control will continue to be cloud-based?
Yes. HomeKit communication is encrypted. Originally, it required specific encryption hardware, but I don't think that's true any more. Anywhere, here are the details:
Seems like it has all that I should need, so I'll give that a try. Is the Alexa app only required for setup/adding into the alexa home, or will the phone always need to be present for it to work, acting as a communication bridge? I have zero alexa hardware - and otherwise don't intend to purchase any.
You'll also need to setup some mechanism of control. Either Echo Speaks or Node-RED. I only know how to do it using Node-RED. Either one will require an always-on server at home - like a Raspberry Pi, or if you have a NAS that supports Docker containers, that'll work too.
Ah, wasn't aware those setups would require a separate dedicated server of sorts - which I don't have... yet! Will definitely keep it in mind as an option for the future though. thanks
If you subscribe to twitter alerts of @rpilocator and are able to react immediately when one comes in, you stand a decent shot of getting a new pi for MSRP.
Or you can try to get a used mini pc or thin client pc to use as a server.
Since I’ve had my pi, I keep finding more and more uses for it. Probably one of the most useful devices in the house.
Anyway, regarding Mysa, I’ve also been somewhat stuck with how to get it into Hubitat. It does also integrate with the SmartThings cloud which doesn’t require a hub. In doing that, I am using the Hubithings Replica integration with the thermostat driver. Just set it up and got it connected but have t done any testing yet. Seems to be the most promising way, but I’ll still probably interact with the Mysa more via HomeKit or just set schedules within the Mysa app
