I have several apple devices and several dozen hubitat devices (Z wave) where I'm using homekit integration to bridge to Apple Homekit. On my personal Apple devices all of the Hubitat devices work as expected in Apple Home. In Apple Home I see 'Home Hubs & Bridges" on all of my Apple devices.
There is a problem when I share Apple Home with a family member. On the family shared apple devices, "Home Hubs & Bridges" does not appear. Research seems to indicate that this is expected behavior for security on Apple devices. However, none of the Hubitat homekit (Z Wave) devices will update properly. They show up in the shared family members Home app, but they remain 'updating/no response'. For Homekit specific devices, they work fine on the family member's apple devices in Home. It's just the Hubitat/homekit integration devices (Z wave) that are 'no response'.
I've gone through the normal troubleshooting steps for rebooting/resetting Hubitat and devices. All work fine on my (the master) devices so I know that communication is happening. I'm thinking it must be a bug with Apple Homekit and family sharing.
Edit: Just realized I don't use the built-in Homekit integration. I share devices via Homebridge. Not sure why that would make a difference at the Apple end, but perhaps it does.
The z-wave devices show on family shares, but have the ‘no response’ message. They used to work last year, I wonder if it might have something to do with iOS 27? Or maybe the HomePod V1 that is acting as the home hub?
I use the built in HomeKit integration. I am on IOS 27. I have Apple TV and HomePod mini’s that act as the HomeKit hubs. And everything updates just fine on my phone and my wife’s.
It seems as though Z-Wave is working for others on family sharing via Homekit integration. Then the question is how to troubleshoot and fix the issue? I've removed and added the Z-Wave devices multiple times. Hubitat and integration are at latest versions. Z-Wave devices have been excluded and included and deleted/removed from Homekit integration. All Apple devices are at 27.2. Z-Wave devices are controllable on all my Apple devices (iPhone Pro Max 16, iPad M4, M5 Mac Studio Max) but show as 'updating' or 'no response' on my friends devices (iPhone SE, iPad Mini)
Are you only sharing Z-Wave devices from Hubitat to Apple Home? If not, do other devices work as expected. You can easily test with a Hubitat virtual switch. Is everyone on the same WiFi network?
I have some Kasa KP115 smartplugs with homekit bridge that work fine on all devices, but others don't show on family shared. All show/control on my devices. The Z-wave device I'm most interested in is an EcoNet200/Bulldog valve. It is in Homekit bridge and shows on all devices, but is 'no response' on family shared. I guess I'll try disabling/enabling homekit bridge again.
What was interesting is that, only recently, some home devices were controllable and others were either missing or showed 'no response' on the family shared devices.
But, now that you mentioned that, I deleted them from home, re-started the shared devices, added them back in as resident again and now all homekit/hubitat devices are showing properly and controllable. Weird. Thanks for pointing me in the right direction! We're off an running!
