Connect a second-hand Hubitat C-5 to an Asus router, and the Mac address is properly loaded on the LAN port, but it does not appear on the client as a networked device.
Why is that?
Try pressing the reset button on the bottom of the hub (only round hole in all the square ones) with a toothpick or paperclip for 7 seconds. This will reset the network settings on the hub,
After having a hard time finding the reset button, it was solved well by the method you told me. Thank you.
So I assume that at some point recently you set a static ip within hubitat itself.... When you do that sometimes the DNS doesn't take hold properly. Setting the dns manually to 1.1.1.1 typically fixes this...
