In some posts, I have seen a reference to a built-in "hubitat API". I don't find his app. is this the same as the Maker API?
Not necessarily. Rule machine has an API too.
It’s called the maker api, look
In built in apps
Actually, the hubitat api is an overarching api for hubitat. There are other api's for maker, ruleMachine, and others.
The base developer documentation is at:
https://docs.hubitat.com/index.php?title=Developer_Documentation
A list of all documentation (with links) can be found at:
https://docs.hubitat.com/index.php?title=Hubitat_Elevation_Documentation
Dave
For reference, here is the specific post I'm referring to. I post this question separately as the post itself is about 2 years old. Tasker+Autolocation Presence Setup [Android Only]
[quote="neonrt7, post:1, topic:13134"]
Hubitat API
If not already added, add the hubitat API under "built in apps"
- Go to "Select Devices"
- Add the virtual presence sensors you just added above
- Take note of the line " Send Device Command (replace [Device ID]..."under the "Cloud URLS"
4.*https://cloud.hubitat.com/api/ ...**- Click on the "Get All Devices" and take note of each device ID (used next step)
- Email yourself the URL and add the commands needed (see below)
Hubitat API
I didn't see a specific "habitat API",and assumed it is Maker API, but am looking for confirmation.
Yup, that post appears to be referring to the maker API.
Thank you for the confirmation!
