My applets for notifying me that the Garage door is open or closed stopped working as of 3 days ago. MyQ is now connected to ifttt and the trigger options are available. It appeared that MyQ and ifttt had been disconnected when I checked the status so I reconnected them.
On my ifttt integration app, my Garage Door virtual contact sensor which is listed in the integration list, does Not appear as a option in The action list in ifttt.
So it appears that ifttt and hubitat are not connected.
Iām not sure where to proceed.
Check the ifttt integration on hubitat and that it's logged in.
Somehow I was able to get them all back connected to each other. Thanks for the reply though.
Honestly this is why I don't involve the cloud in anything really. At least not anything important
Yes . I wound up putting a contact sensor back out there even though I got the ifttt and MyQ connection back up
You know you can connect your myq directly to hubitat with my q lite right? Also you could replace your whole setup with a zen-16 controller.
