Got it; Timelines are a little tricky. The main thing that stops you are the threshold values:
Some are auto filled (motion, etc)
Illuminance needs a threshold. Below is an example of setting the threshold for illuminance.. Was this the issue?
What do the logs say? Steps 1-3 should show the error in the log.
Sounds like something changed in either your devices reporting or you just got out of a "bad" state...
I’m getting HPM errors when I try to upgrade from 4.0. HPM shows the target as 4.25, so I presume that’s correct. I’ve copied the log below—any ideas?
app:30202020-11-29 11:08:44.117 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:44.003 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.856 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.725 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.591 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.452 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.296 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.177 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:43.045 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:42.901 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:42.742 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:42.513 pm errorError upgrading app: groovyx.net.http.HttpResponseException: Server Error
app:30202020-11-29 11:08:42.334 pm infoFatal error occurred, rolling back
app:30202020-11-29 11:08:42.329 pm errorError upgrading driver groovyx.net.http.ResponseParseException: Server Error
app:30202020-11-29 11:08:42.228 pm infoUpgrading Hubigraph Tile Device
app:30202020-11-29 11:08:42.227 pm errorError retrieving driver source: groovyx.net.http.ResponseParseException: Server Error
app:30202020-11-29 11:08:37.321 pm infoUpgrading Hubigraph Weather Tile 2
app:30202020-11-29 11:08:36.132 pm infoUpgrading Hubigraph Radar Tile
app:30202020-11-29 11:08:34.304 pm infoUpgrading Hubigraph Forecast Tile
app:30202020-11-29 11:08:32.207 pm infoUpgrading Hubigraph Weather Tile
app:30202020-11-29 11:08:29.909 pm infoUpgrading Hubigraph Heat Map
app:30202020-11-29 11:08:25.050 pm infoUpgrading Hubigraph Time Graph
app:30202020-11-29 11:08:22.583 pm infoUpgrading Hubigraph Bar Graph
app:30202020-11-29 11:08:19.659 pm infoUpgrading Hubigraph Range Bar
app:30202020-11-29 11:08:16.840 pm infoUpgrading Hubigraph Time Line
app:30202020-11-29 11:08:13.771 pm infoUpgrading Hubigraph Gauge
app:30202020-11-29 11:08:02.543 pm infoUpgrading Hubigraph Line Graph
app:30202020-11-29 11:07:54.930 pm infoUpgrading Hubigraphs
app:30202020-11-29 11:07:54.678 pm infoDownloading Hubigraph OpenWeather Device
app:30202020-11-29 11:07:54.469 pm infoDownloading Hubigraph Tile Device
app:30202020-11-29 11:07:54.162 pm infoDownloading Hubigraph Weather Tile 2
app:30202020-11-29 11:07:53.818 pm infoDownloading Hubigraph Radar Tile
app:30202020-11-29 11:07:53.551 pm infoDownloading Hubigraph Forecast Tile
app:30202020-11-29 11:07:53.294 pm infoDownloading Hubigraph Weather Tile
app:30202020-11-29 11:07:53.047 pm infoDownloading Hubigraph Heat Map
app:30202020-11-29 11:07:52.794 pm infoDownloading Hubigraph Time Graph
app:30202020-11-29 11:07:52.498 pm infoDownloading Hubigraph Bar Graph
app:30202020-11-29 11:07:52.193 pm infoDownloading Hubigraph Range Bar
app:30202020-11-29 11:07:51.962 pm infoDownloading Hubigraph Time Line
app:30202020-11-29 11:07:51.650 pm infoDownloading Hubigraph Gauge
app:30202020-11-29 11:07:51.380 pm infoDownloading Hubigraph Line Graph
app:30202020-11-29 11:07:51.087 pm infoDownloading Hubigraphs
app:30202020-11-29 11:07:50.817 pm infoDownloading https://raw.githubusercontent.com/tchoward/Hubitat/master/WeatherTile2.css
app:30202020-11-29 11:07:50.543 pm infoDownloading https://raw.githubusercontent.com/tchoward/Hubitat/master/WeatherTile2.js
app:30202020-11-29 11:07:50.270 pm infoDownloading https://raw.githubusercontent.com/tchoward/Hubitat/master/WeatherTile.js
app:30202020-11-29 11:07:50.026 pm infoDownloading https://raw.githubusercontent.com/tchoward/Hubitat/master/HubiGraph.js
app:30202020-11-29 11:07:49.428 pm debugPerforming update
app:30202020-11-29 11:07:46.574 pm debugprefPkgVerifyUpdates
app:30202020-11-29 11:07:44.224 pm debugUpdates available
app:30202020-11-29 11:03:33.474 pm debugUpdates available
app:30202020-11-29 10:57:13.128 pm debugUpdates available
app:30202020-11-29 10:55:59.607 pm debugUpdates available
app:30202020-11-29 10:55:57.564 pm infoChecking for updates for At Home Simulator
app:30202020-11-29 10:55:57.313 pm infoChecking for updates for iPhone WiFi Presence Sensor
app:30202020-11-29 10:55:57.119 pm infoChecking for updates for Z-Wave Firmware Updater
app:30202020-11-29 10:55:56.942 pm infoChecking for updates for Device Check Plus
app:30202020-11-29 10:55:56.811 pm infoChecking for updates for Follow Me
app:30202020-11-29 10:55:56.676 pm infoChecking for updates for BI Control
app:30202020-11-29 10:55:56.434 pm infoChecking for updates for Life360 with States
app:30202020-11-29 10:55:56.187 pm infoChecking for updates for Hubitat-BetterLaundryMonitor
app:30202020-11-29 10:55:55.991 pm infoChecking for updates for Hubitat Package Manager
app:30202020-11-29 10:55:55.737 pm infoChecking for updates for Reliable Locks
app:30202020-11-29 10:55:55.547 pm infoChecking for updates for DarkSky.net Weather Driver
app:30202020-11-29 10:55:55.545 pm debugUpdates found package for https://raw.githubusercontent.com/tchoward/Hubitat/master/packageManifest.json -> null (force production: true)
app:30202020-11-29 10:55:55.541 pm debugUpdates found for package https://raw.githubusercontent.com/tchoward/Hubitat/master/packageManifest.json
app:30202020-11-29 10:55:55.259 pm infoChecking for updates for HubiGraphs
app:30202020-11-29 10:55:55.074 pm infoChecking for updates for Package Explorer
app:30202020-11-29 10:55:54.974 pm infoChecking for updates for Life360 Tracker
app:30202020-11-29 10:55:54.837 pm infoChecking for updates for Hub Watchdog
app:30202020-11-29 10:55:54.642 pm infoChecking for updates for HTTP Presence Sensor
app:30202020-11-29 10:55:54.437 pm infoChecking for updates for Device Watchdog
app:30202020-11-29 10:55:54.181 pm infoChecking for updates for Log Watchdog
app:30202020-11-29 10:55:53.945 pm infoChecking for updates for Inovelli Drivers (Gen 2)
app:30202020-11-29 10:55:53.708 pm infoChecking for updates for Lockdown
app:30202020-11-29 10:55:53.528 pm infoChecking for updates for HubConnect_v2_UnversalDrivers
app:30202020-11-29 10:55:53.223 pm infoChecking for updates for Tile Master
app:30202020-11-29 10:55:52.984 pm debugUpdate chosen
app:30202020-11-29 10:54:16.646 pm debugRefreshing repository list
Anyone else with the > 1024 error ? I'm getting this error and my tile is displaying weather from the first day I set up the app. I've uninstalled and reinstalled the weather child apps with no change.
2020-12-01 04:20:05.410 pm warnExcluded attribute current_weather size of attribute > 1024 characters
I get the same >1024 error, but haven't noticed any ill effects.
Sometimes this error is seen; I have not seen it affect anything. If it does please let me know!
I posted this because my weather tile is not providing current weather. I'm not concerned with meaningless error messages. This is two day old info that does not update.
@thomas.c.howard, any idea about HPM error a couple messages up in the thread?
Yes; your best bet is to do a repair on HubiGraph through HPM
Ok; I’ll take a look. This is cause by the weather data being greater than 1024 characters. You must have a lot of weather activity... I will need to do some refactoring...
That did the trick, tyvm
I'm getting this error thrown roughly every 2 seconds. Repair of the app through HPM had no impact. Uninstalling fails "Fatal Error occurs" on the OpenWeather device and attempts to roll back, which hangs indefinitely. Had to manually delete the child device, then manually deleted the device driver and app code (dunno if I had to do it all manually, but once I got the driver removed, I just blew it all away).
Hmmm... I wonder why. I am sorry for the experience; give me a day or two and I’ll get a fix
Some more context, not sure if it's helpful: I was seeing the "Excluded attribute current_weather size..." warn message infrequently prior to upgrading the hub to 2.2.4.153. After the upgrade, that's when it went to 2 seconds. Prior to moving to 2.2.4.153, I cannot remember if I had rebooted the hub after installing hubigraphs (upgrading actually... been installed for some time but I hadn't been playing with it recently, definitely not since the weather related additions).
Apologies for the lack of specifics, my toddler eats up all my spare time these days, rather than tinkering with home automation. Love the tool though!
I had a similar experience. I was seeing the message periodically but then it went to every 2 seconds. I’m still running version 2.2.4.148.
This seems to be a combination of two things:
There is an attribute size limit. I was “cheating” and storing the response from OpenWeather as a string for use by WeatherTiles later. It looks like with winter upon us there are some places that are breaking the limit.
It seems in the latest firmware, having this occur (see #1) behaves differently.
I will be working a fix; could be a quick fix... or not... stay tuned.
@Charli3_Tang0, @nibyak , @bbrannon, @scotte
I have updated the build to 4.30. It includes a paradigm that stores the weather data in state as opposed as an attribute. This should fix the < 1024 issue that you have been seeing. Please give it a try and let me know if it fixes the issues.
Thanks, I've got it working now. Created a new Weather Tile 2 and it looks to be good.
Confirmed that the "<1024" log is resolved with 4.30. (I never saw any issues, so can only confirm that there aren't log entries anymore.)
