A small suggestion for consideration, I see a number of your examples have a great colour schemes in this thread. Would be nice to have some templated colour schemes for the graphs or a way for people to share and import “themes”
@TemptingTime: Ok; did some rework. I believe it is fixed. I proved it out with an Open Weather driver. I was able to graph "weather" which had 9 different states. Hopefully this is the last iteration. Fix is uploaded.
Thank you for creating this awesome App. I tested and it worked!
The only issue is the option to add 'non standard's states was actually on the temperature attribute and not the operating system, but it was able to pull properly and the graph showed up. Now I just have to toy with it a bit to make it more legible.
Thanks for testing. Weird result... Did you start fresh? I am glad it is working. So, the way it should work is the sensor (thermostat) -> attribute (operating state) -> custom states... All (non-known -- or numerical) types should allow the user to select custom types now. As n example, I set up the following graph as a test:
Question for folks: my first attempt is a column chart with ranges to map the temperatures of a handful of sensors in my house. The y-axis seems to default to 0-100 degrees, which deemphasizes the variation, so I changed the range to 50-90 to "zoom in", thinking the y-axis would simply re-scale. But when I do that, the graph no longer plots. No error messages in the log. Any ideas?
Just tried a Heat Map and it is really nice! Very useful when you have way too many sensors and want to see what is happening at a glance... Here's what it looks like for me with Temperature:
I must be missing something... I can't seem to find where the graph can be configured to display horizontally vs vertically... I'd love to know how you were able to get yours to display vertically!
@Sebastien, how long did it take for the app to go through the 4 steps to render the heat map? It's taking quite a while for me. Mine is the same size as yours.
