If you need it here is the code. Import this into APPS code
Summary
definition(
namespace: "tchoward",
author: "Thomas Howard",
description: "Hubitat Graph Creator Parent App",
category: "My Apps",
installOnOpen: true,
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
//V 1.0 Ordering, Color and Common API Update
//V 1.8 Smoother sliders, bug fixes
//V 2.0 Support for Time Graphs
//V 2.1 Support for Heatmaps
//V 3.3 Radar Tiles
//V 0.1 Beta - Weather Tiles 2
preferences {
// The parent app preferences are pretty simple: just use the app input for the child app.
page(name: "mainPage", title: "Graph Creator", install: true, uninstall: true, submitOnChange: true)
page(name: "setupOpenWeather", title: "Setup Open Weather", nextPage: "mainPage")
page(name: "setupLongTermStorage", title: "Setup Long Term Storage")
def call(Closure code) {
code.setResolveStrategy(Closure.DELEGATE_ONLY);
code.setDelegate(this);
code.call();
def getLongTermStorage() {
lts = getChildAppByLabel("Hubigraph Long Term Storage")
def getEvents(Map map){
sensor = map.sensor;
attribute = map.attribute;
then = map.start_time;
respEvents = sensor.statesSince(attribute, then, [max: 2000]).collect{[ date: it.date, value: it.value]}
respEvents = respEvents.flatten();
respEvents = respEvents.reverse();
return respEvents;
def getData(sensor, attribute, lts, time){
return_data = [];
then = time;
if (lts) {
ltsApp = getChildAppByLabel("Hubigraph Long Term Storage");
return_data = ltsApp.getFileData(sensor, attribute);
if (return_data.size()> 0)
then = return_data[return_data.size()-1].date;
events = getEvents(sensor: sensor, attribute: attribute, start_time: then);
return_data = (return_data << events).flatten();
return return_data;
def ltsAvailable(sensor, attribute){
lts = getChildAppByLabel("Hubigraph Long Term Storage");
if (lts!=null){
return lts.isStorage(sensor, attribute);
else {
return false;
def mainPage(){
if (latitude && longitude && apikey) {
childDevice = getChildDevice("OPEN_WEATHER${app.id}");
log.debug(childDevice);
if (!childDevice) {
device_name="Open Weather Child Device";
log.debug("Creating Device $device_name");
childDevice = addChildDevice("tchoward", "OpenWeather Hubigraph Driver", "OPEN_WEATHER${app.id}", null,[completedSetup: true, label: device_name])
log.info "Successfully Created Child"
if (childDevice) {
childDevice.setupDevice(latitude: latitude, longitude: longitude, apiKey: apikey, pollInterval: open_weather_refresh_rate);
childDevice.pollData();
dynamicPage(name: "mainPage"){
section {
app(name: "hubiStorage", appName: "Hubigraph Long Term Storage", namespace: "tchoward", title: "Setup Long Term Storage", multiple: true)
section {
app(name: "hubiWidget", appName: "Hubigraph Bubble Widget", namespace: "tchoward", title: "Create New Bubble Widget", multiple: true)
app(name: "hubiBarGraph", appName: "Hubigraph Bar Graph", namespace: "tchoward", title: "Create New Bar Graph", multiple: true)
app(name: "hubiRangeBar", appName: "Hubigraph Range Bar", namespace: "tchoward", title: "Create New Range Bar", multiple: true)
app(name: "hubiGraphTime", appName: "Hubigraph Time Line", namespace: "tchoward", title: "Create New Time Line", multiple: true)
app(name: "hubiGauge", appName: "Hubigraph Gauge", namespace: "tchoward", title: "Create New Gauge", multiple: true)
app(name: "hubiTimeGraph", appName: "Hubigraph Time Graph", namespace: "tchoward", title: "Create New Time Graph", multiple: true)
app(name: "hubiHeatMap", appName: "Hubigraph Heat Map", namespace: "tchoward", title: "Create New Heat Map", multiple: true)
app(name: "hubiWeather", appName: "Hubigraph Weather Tile", namespace: "tchoward", title: "Create New Weather Tile", multiple: true)
app(name: "hubiForecast", appName: "Hubigraph Forecast Tile", namespace: "tchoward", title: "Create New Forecast Tile", multiple: true)
app(name: "hubiWeather2", appName: "Hubigraph Weather Tile 2", namespace: "tchoward", title: "Create New Weather Tile 2", multiple: true)
app(name: "hubiRadar", appName: "Hubigraph Radar Tile", namespace: "tchoward", title: "Create New Radar Tile", multiple: true)
section {
href name: "setupOpenWeather", title: "Setup Up Open Weather for Weather Tile", description: "", page: "setupOpenWeather"
def setupOpenWeather(){
def updateEnum = ['Manual Poll Only','1 Minute','5 Minutes', '10 Minutes', '15 Minutes', '30 Minutes', '1 Hour', '3 Hours'];
def location = getLocation();
dynamicPage(name: "setupOpenWeather"){
section{
input( type: "enum", name: "open_weather_refresh_rate", title: "<b>Select OpenWeather Update Rate</b>", multiple: false, required: false, options: updateEnum, defaultValue: "5 Minutes");
input( type: "text", name: "latitude", title:"<b>Latitude (Default = Hub Location)</b>", defaultValue: location.latitude);
input( type: "text", name: "longitude", title:"<b>Longitude (Default = Hub Location)</b>", defaultValue: location.longitude);
input( type: "text", name: "apikey", title: "<b>OpenWeather Key</b>", defaultValue:"", submitOnChange: true);
def getOpenWeatherData(){
if (!childDevice){
log.debug("Error: No Child Found");
return null;
return(childDevice.getWeatherData());
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
// nothing needed here, since the child apps will handle preferences/subscriptions
// this just logs some messages for demo/information purposes
log.debug "there are ${childApps.size()} child smartapps"
childApps.each {child ->
log.debug "child app: ${child.label}"
****************************************** NEW FORM FUNCTIONS********************************************************************
def hubiForm_container(child, containers, numPerRow=1){
if (numPerRow == 0){
style = """style="margin: 0 !important; padding: 0 !important;"""
numPerRow = 1
} else {
style = "";
child.call(){
def html_ =
<div class = "mdl-grid" style="margin: 0 !important; padding: 0 !important;">
containers.each{container->
html_ += """<div class="mdl-cell mdl-cell--${12/numPerRow}-col-desktop mdl-cell--${8/numPerRow}-col-tablet mdl-cell--${4/numPerRow}-col-phone" ${style}>"""
html_ += container;
html_ += """</div>"""
paragraph (html_.replace('\t', '').replace('\n', '').replace(' ', ''));
def hubiForm_subcontainer(Map map, child){
child.call(){
def containers = map.objects;
def breakdown = map.breakdown;
def html_ =
<div class = "mdl-grid" style="margin: 0; padding: 0; ">
count = 0;
def sz_12 = 12*breakdown[count];
def sz_8 = 8*breakdown[count];
def sz_4 = 4*breakdown[count];
html_ += """<div class="mdl-cell mdl-cell--${sz_12.intValue()}-col-desktop mdl-cell--${sz_8.intValue()}-col-tablet mdl-cell--${sz_4.intValue()}-col-phone" style= "justify-content: center;" >"""
html_ += container;
count++;
return (html_.replace('\t', '').replace('\n', '').replace(' ', ''));
def hubiForm_table(Map map, child){
child.call(){
def header = map.header;
def rows = map.rows;
def footer = map.footer;
def html_ = """
<table class="mdl-data-table mdl-shadow--2dp dataTable" role="grid" data-upgraded=",MaterialDataTable">
<thead><tr>
header.each{cell->
html_ += """<th class="mdl-data-table__cell--non-numeric ">${cell}</th>"""
html+= """</tr></thead><tbody>"""
count = 0;
rows.each{row->
html_ += """<tr role="row" class="odd">""";
row.each{cell->
html_ += """<td class="mdl-data-table__cell--non-numeric">${cell}</td>""";
html_ += """</tr>""";
} //rows
html_ += """<tr role="row" class="even">""";
footer.each{cell->
html_ += """</tbody></table>"""
def hubiForm_text(child, text, link=null){
child.call(){
def html_ = "";
if (link != null){
html_ = """<a href="${link}" target="_blank">${text}</a>""";
} else {
html_ = """${text}""";
return html_
def hubiForm_text_format(Map map, child){
child.call(){
def text = map.text;
def halign = map.horizontal_align ? "text-align: ${map.horizontal_align};" : "";
def valign = map.vertical_align ? "vertical-align: ${map.vertical_align}; " : "";
def size = map.size ? "font-size: ${map.size}px;" : "";
def html_ = """<p style="$halign padding-top:20px; $size">$text</p>""";
return html_
def hubiForm_page_button(child, title, page, width, icon=""){
def html_;
child.call(){
html_ = """
<button type="button" name="_action_href_${page}|${page}|1" class="btn btn-default btn-lg btn-block hrefElem mdl-button--raised mdl-shadow--2dp mdl-button__icon" style="text-align:left;width:${width}; margin: 0;">
<span style="text-align:left;white-space:pre-wrap">
${title}
</span>
<ul class="nav nav-pills pull-right">
<li><i class="material-icons">${icon}</i></li>
</ul>
<br>
<span class="state-incomplete-text " style="text-align: left; white-space:pre-wrap"></span>
</button>
""".replace('\t', '').replace('\n', '').replace(' ', '')
return html_;
def hubiForm_section(child, title, pos, icon="", Closure code) {
child.call(){
def id = title.replace(' ', '_').replace('(', '').replace(')','');
def title_ = title.replace("'", "").replace("`", "");
def titleHTML = """
<div class="mdl-layout__header" style="display: block; background:#033673; margin: 0 -16px; width: calc(100% + 32px); position: relative; z-index: ${pos}; overflow: visible;">
<div class="mdl-layout__header-row">
<span class="mdl-layout__title" style="margin-left: -32px; font-size: 18px; width: auto;">
${title_}
</span>
<div class="mdl-layout-spacer"></div>
<li> <i class="material-icons">${icon}</i></li>
</ul>
</div>
</div>
def modContent = """
<div id=${id} style="display: none;"></div>
<script>
var sectionElem = jQuery('#${id}').parent();
/*hide default header*/
sectionElem.css('display', 'none');
sectionElem.css('z-index', ${pos});
var elem = sectionElem.parent().parent();
elem.addClass('mdl-card mdl-card-wide mdl-shadow--8dp');
elem.css('width', '100%');
elem.css('padding', '0 16px');
elem.css('display', 'block');
elem.css('min-height', 0);
elem.css('position', 'relative');
elem.css('z-index', ${pos});
elem.css('overflow', 'visible');
elem.prepend('${titleHTML}');
</script>
modContent = modContent.replace('\t', '').replace('\n', '').replace(' ', '');
section(modContent, code);
def hubiForm_enum(Map map, child){
child.call(){
def title = map.title;
def var = map.name;
def list = map.list;
def defaultVal = map.default;
def submit_on_change = map.submit_on_change;
if (settings[var] == null){
app.updateSetting ("${var}", defaultVal);
def actualVal = settings[var] != null ? "${settings[var]}" : defaultVal;
def submitOnChange = submit_on_change ? "submitOnChange" : "";
def html_ = """
<div class="form-group">
<input type="hidden" name="${var}.type" value="enum">
<input type="hidden" name="${var}.multiple" value="false">
</div>
<div class="mdl-cell mdl-cell--12-col mdl-textfield mdl-js-textfield" style="" data-upgraded=",MaterialTextfield">
<label for="settings[${var}]" class="control-label">
<b>${title}</b>
</label>
<select id="settings[${var}]" name="settings[${var}]"
class="selectpicker form-control mdl-switch__input ${submitOnChange} SumoUnder" placeholder="Click to set" data-default="${defaultVal}" tabindex="-1">
<option class="optiondefault" value="" style="display: block;">No selection</option>
list.each{ item ->
if (actualVal == item)
selectedString = /selected="selected"/;
else
selectedString = "";
html_ += """<option value="${item}" ${selectedString}>${item}</option>"""
html_ += """
</select>
<div class="optWrapper">
<ul class="options">
list.each{ item ->
html+= """<li class="opt selected"><label>${item}</label></li>"""
html_ += """
</ul>
</div>
</div>
def hubiForm_switch(Map map, child){
child.call(){
def var = map.name;
def actualVal = settings[var] != null ? settings[var] : defaultVal;
def html_ = """
<input type="hidden" name="${var}.type" value="bool">
</div>
class="mdl-switch mdl-js-switch mdl-js-ripple-effect mdl-js-ripple-effect--ignore-events is-upgraded ${actualVal ? "is-checked" : ""}
data-upgraded=",MaterialSwitch,MaterialRipple">
<input name="checkbox[${var}]" id="settings[${var}]" class="mdl-switch__input
${submitOnChange}"
type="checkbox"
${actualVal ? "checked" : ""}>
<div class="mdl-switch__label" >${title}</div>
<div class="mdl-switch__track"></div>
<div class="mdl-switch__thumb">
<span class="mdl-switch__focus-helper">
</span>
</div>
<span class="mdl-switch__ripple-container mdl-js-ripple-effect mdl-ripple--center" data-upgraded=",MaterialRipple">
<span class="mdl-ripple">
</span>
</span>
</label>
<input name="settings[${var}]" type="hidden" value="${actualVal}">
def hubiForm_text_input(child, title, var, defaultVal, submitOnChange){
child.call(){
settings[var] = settings[var] != null ? settings[var] : defaultVal;
def html_ = """
<input type="hidden" name="${var}.type" value="text">
</div>
${title}
</label>
<input type="text" name="settings[${var}]"
class="mdl-textfield__input ${submitOnChange ? "submitOnChange" : ""} "
value="${settings[var]}" placeholder="Click to set" id="settings[${var}]">
return html_.replace('\t', '').replace('\n', '').replace(' ', '');
def hubiForm_font_size(Map map, child){
child.call(){
def varname = map.name;
def default_ = map.default;
def min = map.min;
def max = map.max;
def baseId = varname;
def varFontSize = "${varname}_font"
settings[varFontSize] = settings[varFontSize] ? settings[varFontSize] : default_;
def html_ =
<table style="width:100%">
<tr><td><label for="settings[${varFontSize}]" class="control-label"><b>${title} Font Size</b></td>
<td >
<span id="${baseId}_font_size_val" style="text-align:right; font-size:${settings[varFontSize]}px">Font Size: ${settings[varFontSize]}</span>
</td>
</label>
</tr>
</table>
<input type="range" min = "$min" max = "$max" name="settings[${varFontSize}]"
class="mdl-slider $submit_on_change "
value="${settings[varFontSize]}"
id="settings[${varFontSize}]"
onchange="${baseId}_updateFontSize(this.value);">
<input type="hidden" name="${varFontSize}.type" value="number">
<input type="hidden" name="${varFontSize}.multiple" value="false">
</div>
<script>
function ${baseId}_updateFontSize(val) {
var text = "";
text += "Font Size: "+val;
jQuery('#${baseId}_font_size_val').css("font-size", val+"px");
jQuery('#${baseId}_font_size_val').text(text);
</script>
def hubiForm_fontvx_size(Map map, child){
child.call(){
def min = map.min;
def max = map.max;
def weight = map.weight ? "font-weight: ${map.weight} !important;" : "";
def icon = null;
def icon_size = settings[varFontSize] ? 10*settings[varFontSize] : default_*10;
def jq = "";
if (map.icon){
icon = """
<style>
.material-icons.test { font-size: ${icon_size}px; }
</style>
<i id="${baseId}_icon" class="material-icons test">cloud</i>
jq = """jQuery('.test').css('font-size', 10*val+"px");"""
} else {
jq = """
jQuery('#${baseId}_font_size_val').css("font-size", 0.5*val+"em");
def html_ =
<label for="settings[${varFontSize}]" class="control-label" style= "vertical-align: bottom;">
<b>${title}</b>
<span id="${baseId}_font_size_val" style="float:right; font-size: ${settings[varFontSize]*0.5}em; ${weight}">
${icon == null ? settings[varFontSize] : icon}
</span>
</label>
</div>
<script>
var text = "";
text += val;"""
html_+= jq;
html_+="""
</script>
def hubiForm_line_size(Map map, child){
child.call(){
def min = map.min;
def max = map.max;
def varLineSize = "${varname}_line_size"
settings[varLineSize] = settings[varLineSize] ? settings[varLineSize] : default_;
def html_ =
<tr><td><label for="settings[${varLineSize}]" class="control-label"><b>${title} Width</b></td>
<td border=1 style="text-align:right;">
<span id="${baseId}_line_size_text" name="testing" >
Width: ${settings[varLineSize]} <hr id='${baseId}_line_size_draw' style='background-color:#1A77C9; height:${settings[varLineSize]}px; border: 0;'>
</span>
</td>
</label>
</tr>
</table>
<input type="range" min = "$min" max = "$max" name="settings[${varLineSize}]"
class="mdl-slider ${submitOnChange}"
value="${settings[varLineSize]}"
id="settings[${varLineSize}]"
onchange="${baseId}_updateLineInput(this.value);">
<input type="hidden" name="${varLineSize}.type" value="number">
<input type="hidden" name="${varLineSize}.multiple" value="false">
</div>
<script>
function ${baseId}_updateLineInput(val) {
var text = "";
text += "Width: "+val;
jQuery('#${baseId}_line_size_text').text(text);
jQuery('#${baseId}_line_size_draw').remove();
jQuery('#${baseId}_line_size_text').after("<hr id='${baseId}_line_size_draw' style='background-color:#1A77C9; height:"+val+"px; border: 0;'>");
</script>
def hubiForm_slider(Map map, child){
child.call(){
def min = map.min;
def max = map.max;
def units = map.units;
def fontSize;
def varSize = "${varname}"
def baseId = "${varname}";
settings[varSize] = settings[varSize] ? settings[varSize] : default_;
def html_ =
<tr><td><label for="settings[${varSize}]" class="control-label"><b>${title}</b></td>
<td border=1 style="text-align:right;"><span id="${baseId}_slider_val" name="testing" >${settings[varSize]}${units}</span></td>
</label>
</tr>
</table>
<input type="range" min = "$min" max = "$max" name="settings[${varSize}]"
class="mdl-slider $submitOnChange "
value="${settings[varSize]}"
id="settings[${varSize}]"
onchange="${baseId}_updateTextInput(this.value);">
<input type="hidden" name="${varSize}.type" value="number">
<input type="hidden" name="${varSize}.multiple" value="false">
</div>
<script>
function ${baseId}_updateTextInput(val) {
var text = "";
text += val+"${units}";
jQuery('#${baseId}_slider_val').text(text);
</script>
def hubiForm_color(child, title, varname, defaultColorValue, defaultTransparentValue, submit = false){
child.call(){
def varnameColor = "${varname}_color";
def varnameTransparent = "${varname}_color_transparent"
def colorTitle = "<b>${title} Color</b>"
def notTransparentTitle = "Transparent";
def transparentTitle = "${title}: Transparent"
settings[varnameColor] = settings[varnameColor] ? settings[varnameColor]: defaultColorValue;
settings[varnameTransparent] = settings[varnameTransparent] ? settings[varnameTransparent]: defaultTransparentValue;
def isTransparent = settings[varnameTransparent];
def html_ =
<div style="display: flex; flex-flow: row wrap;">
<div style="display: flex; flex-flow: row nowrap; flex-basis: 100%;">
${!isTransparent ? """<label for="settings[${varnameColor}]" class="control-label" style="flex-grow: 1">${colorTitle}</label>""" : """"""}
<label for="settings[${varnameTransparent}]" class="control-label" style="width: auto;">${isTransparent ? transparentTitle: notTransparentTitle}</label>
</div>
<div style="flex-grow: 1; flex-basis: 1px; padding-right: 8px;">
<input type="color" name="settings[${varnameColor}]" class="mdl-textfield__input ${submit ? "submitOnChange" : ""} " value="${settings[varnameColor] ? settings[varnameColor] : defaultColorValue}" placeholder="Click to set" id="settings[${varnameColor}]" list="presetColors">
<datalist id="presetColors">
<option>#800000</option>
<option>#FF0000</option>
<option>#FFA500</option>
<option>#FFFF00</option>
<option>#808000</option>
<option>#008000</option>
<option>#00FF00</option>
<option>#800080</option>
<option>#FF00FF</option>
<option>#000080</option>
<option>#0000FF</option>
<option>#00FFFF</option>
<option>#FFFFFF</option>
<option>#C0C0C0</option>
<option>#000000</option>
</datalist>
</div>
<div class="submitOnChange">
<input name="checkbox[${varnameTransparent}]" id="settings[${varnameTransparent}]" style="width: 27.6px; height: 27.6px;" type="checkbox" onmousedown="((e) => { jQuery('#${varnameTransparent}').val('${!isTransparent}'); })()" ${isTransparent ? 'checked' : ''} />
<input id="${varnameTransparent}" name="settings[${varnameTransparent}]" type="hidden" value="${isTransparent}" />
</div>
<input type="hidden" name="${varnameColor}.type" value="color">
<input type="hidden" name="${varnameColor}.multiple" value="false">
<input type="hidden" name="${varnameTransparent}.type" value="bool">
<input type="hidden" name="${varnameTransparent}.multiple" value="false">
</div>
</div>
def hubiForm_graph_preview(child){
child.call(){
if (!state.count_) state.count_ = 7;
def html_ =
<style>
.iframe-container {
overflow: hidden;
width: 45vmin;
height: 45vmin;
position: relative;
.iframe-container iframe {
border: 0;
left: 0;
position: absolute;
top: 0;
</style>
<div class="iframe-container">
<iframe id="preview_frame" style="width: 100%; height: 100%; position: relative; z-index: 1; background-image: url('data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAIAAAACCAIAAAD91JpzAAAEq2lUWHRYTUw6Y29tLmFkb2JlLnhtcAAAAAAAPD94cGFja2V0IGJlZ2luPSLvu78iIGlkPSJXNU0wTXBDZWhpSHpyZVN6TlRjemtjOWQiPz4KPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyIgeDp4bXB0az0iWE1QIENvcmUgNS41LjAiPgogPHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4KICA8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0iIgogICAgeG1sbnM6ZXhpZj0iaHR0cDovL25zLmFkb2JlLmNvbS9leGlmLzEuMC8iCiAgICB4bWxuczp0aWZmPSJodHRwOi8vbnMuYWRvYmUuY29tL3RpZmYvMS4wLyIKICAgIHhtbG5zOnBob3Rvc2hvcD0iaHR0cDovL25zLmFkb2JlLmNvbS9waG90b3Nob3AvMS4wLyIKICAgIHhtbG5zOnhtcD0iaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLyIKICAgIHhtbG5zOnhtcE1NPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvbW0vIgogICAgeG1sbnM6c3RFdnQ9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC9zVHlwZS9SZXNvdXJjZUV2ZW50IyIKICAgZXhpZjpQaXhlbFhEaW1lbnNpb249IjIiCiAgIGV4aWY6UGl4ZWxZRGltZW5zaW9uPSIyIgogICBleGlmOkNvbG9yU3BhY2U9IjEiCiAgIHRpZmY6SW1hZ2VXaWR0aD0iMiIKICAgdGlmZjpJbWFnZUxlbmd0aD0iMiIKICAgdGlmZjpSZXNvbHV0aW9uVW5pdD0iMiIKICAgdGlmZjpYUmVzb2x1dGlvbj0iNzIuMCIKICAgdGlmZjpZUmVzb2x1dGlvbj0iNzIuMCIKICAgcGhvdG9zaG9wOkNvbG9yTW9kZT0iMyIKICAgcGhvdG9zaG9wOklDQ1Byb2ZpbGU9InNSR0IgSUVDNjE5NjYtMi4xIgogICB4bXA6TW9kaWZ5RGF0ZT0iMjAyMC0wNi0wMlQxOTo0NzowNS0wNDowMCIKICAgeG1wOk1ldGFkYXRhRGF0ZT0iMjAyMC0wNi0wMlQxOTo0NzowNS0wNDowMCI+CiAgIDx4bXBNTTpIaXN0b3J5PgogICAgPHJkZjpTZXE+CiAgICAgPHJkZjpsaQogICAgICBzdEV2dDphY3Rpb249InByb2R1Y2VkIgogICAgICBzdEV2dDpzb2Z0d2FyZUFnZW50PSJBZmZpbml0eSBQaG90byAxLjguMyIKICAgICAgc3RFdnQ6d2hlbj0iMjAyMC0wNi0wMlQxOTo0NzowNS0wNDowMCIvPgogICAgPC9yZGY6U2VxPgogICA8L3htcE1NOkhpc3Rvcnk+CiAgPC9yZGY6RGVzY3JpcHRpb24+CiA8L3JkZjpSREY+CjwveDp4bXBtZXRhPgo8P3hwYWNrZXQgZW5kPSJyIj8+IC4TuwAAAYRpQ0NQc1JHQiBJRUM2MTk2Ni0yLjEAACiRdZE7SwNBFEaPiRrxQQQFLSyCRiuVGEG0sUjwBWqRRPDVbDYvIYnLboIEW8E2oCDa+Cr0F2grWAuCoghiZWGtaKOy3k2EBIkzzL2Hb+ZeZr4BWyippoxqD6TSGT0w4XPNLyy6HM/UYqONfroU1dBmguMh/h0fd1RZ+abP6vX/uYqjIRI1VKiqEx5VNT0jPCk8vZbRLN4WblUTSkT4VLhXlwsK31p6uMgvFseL/GWxHgr4wdYs7IqXcbiM1YSeEpaX404ls+rvfayXNEbTc0HJnbI6MAgwgQ8XU4zhZ4gBRiQO0YdXHBoQ7yrXewr1s6xKrSpRI4fOCnESZOgVNSvdo5JjokdlJslZ/v/11YgNeovdG31Q82Sab93g2ILvvGl+Hprm9xHYH+EiXapfPYDhd9HzJc29D84NOLssaeEdON+E9gdN0ZWCZJdli8Xg9QSaFqDlGuqXip797nN8D6F1+aor2N2DHjnvXP4Bhcln9Ef7rWMAAAAJcEhZcwAACxMAAAsTAQCanBgAAAAXSURBVAiZY7hw4cL///8Z////f/HiRQBMEQrfQiLDpgAAAABJRU5ErkJggg=='); background-size: 25px; background-repeat: repeat; image-rendering: pixelated;" src="${state.localEndpointURL}graph/?access_token=${state.endpointSecret}" data-fullscreen="false"
onload="(() => {
})()""></iframe>
</div>
def hubiForm_sub_section(child, myText=""){
child.call(){
def id = myText.replaceAll("[^a-zA-Z0-9]", "");
def newText = myText.replaceAll("'", "").replaceAll("`", "")
def html_ =
<div class="mdl-layout__header" style="display: block; min-height: 0;">
<div class="mdl-layout__header-row" style="height: 48px;">
<span class="mdl-layout__title" style="margin-left: -32px; font-size: 9px; width: auto;">
<h4 id="${id}" style="font-size: 16px;">${newText}</h5>
</span>
</div>
</div>
def hubiForm_cell(child, containers, numPerRow){
child.call(){
def html_ =
<div class = "mdl-grid mdl-grid--no-spacing mdl-shadow--4dp" style="margin-top: 0px !important; margin: 0px; padding: 0px 0px;">
html_ += """<div class="mdl-cell mdl-cell--${12/numPerRow}-col-desktop mdl-cell--${8/numPerRow}-col-tablet mdl-cell--${4/numPerRow}-col-phone">"""
html_ += container;
def hubiForm_list_reorder(child, var, var_color, solid_background="") {
child.call(){
def count_ = 0;
if (settings["${var}"] != null){
list_ = parent.hubiTools_get_order(settings["${var}"]);
//Check List
result_ = true;
count_ = 0;
//check for addition/changes
sensors.each { sensor ->
id = sensor.id;
attributes = settings["attributes_${id}"];
attributes.each { attribute ->
count_ ++;
inner_result = false;
for (i=0; i<list_.size(); i++){
if (list_[i].id == id && list_[i].attribute == attribute){
inner_result = true;
result_ = result_ & inner_result;
//check for smaller
count_result = false;
if (list_.size() == count_){
count_result = true;
result_ = result_ & count_result;
if (result_ == false) {
settings["${var}"] = null;
//build list order
list_data = [];
//Setup Original Ordering
if (settings["${var}"] == null){
settings["${var}"] = "[";
attributes = settings["attributes_${sensor.id}"];
settings["${var}"] += /"attribute_${sensor.id}_${attribute}",/
if (settings["attribute_${sensor.id}_${attribute}_${var_color}_color"] == null){
if (solid_background== ""){
settings["attribute_${sensor.id}_${attribute}_${var_color}_color"] = parent.hubiTools_rotating_colors(count_);
} else {
settings["attribute_${sensor.id}_${attribute}_${var_color}_color"] = solid_background;
count_++;
settings["${var}"] = settings["${var}"].substring(0, settings["${var}"].length() - 1);
settings["${var}"] += "]";
count_ = 0;
order_ = parent.hubiTools_get_order(settings["${var}"]);
order_.each { device_->
deviceName_ = parent.hubiTools_get_name_from_id(device_.id, sensors);
title_ = """<b>${deviceName_}</b><br><p style="float: right;">${device_.attribute}</p>""";
title_.replace("'", "").replace("`", "");
list_data << [title: title_, var: "attribute_${device_.id}_${device_.attribute}"];
def var_val_ = settings["${var}"].replace('"', '"');
def html_ =
<script>
function onOrderChange(order) {
jQuery("#settings${var}").val(JSON.stringify(order));
</script>
<script src="/local/a930f16d-d5f4-4f37-b874-6b0dcfd47ace-HubiGraph.js"></script>
<div id = "moveable" class = "mdl-grid" style="margin: 0; padding: 0; text-color: white !important">
list_data.each{data->
color_ = settings["${data.var}_${var_color}_color"];
id_ = "${data.var}"
html_ += """<div id="$id_" class="mdl-cell mdl-cell--12-col-desktop mdl-cell--8-col-tablet mdl-cell--4-col-phone mdl-shadow--4dp mdl-color-text--indigo-400"
draggable="true" ondragover="dragOver(event)" ondragstart="dragStart(event)" ondragend= "dragEnd(event)"
style = "font-size: 16px !important; margin: 8px !important; padding: 14px !important;">
<i class="mdl-icon-toggle__label material-icons" style="color: ${color_} !important;">fiber_manual_record</i>
html_ += data.title;
html_ += """</div>
html_ += """</div>
<input type="text" id="settings${var}" name="settings[${var}]" value="${var_val_}" style="display: none;" disabled />
</div>"""
html_ = html_.replace('\t', '').replace('\n', '').replace(' ', '');
paragraph (html_);
****************************************** TOOLS ********************************************************************************
def hubiTool_create_tile(child, location="graph") {
child.call(){
log.info "Creating HubiGraph Child Device"
def childDevice = getChildDevice("HUBIGRAPH_${app.id}");
if (!childDevice) {
if (!device_name) device_name="Dummy Device";
childDevice = addChildDevice("tchoward", "Hubigraph Tile Device", "HUBIGRAPH_${app.id}", null,[completedSetup: true, label: device_name])
log.info "Created HTTP Switch [${childDevice}]"
//Send the html automatically
childDevice.setGraph("${state.localEndpointURL}${location}/?access_token=${state.endpointSecret}");
log.info "Sent setGraph: ${state.localEndpointURL}${location}/?access_token=${state.endpointSecret}"
else {
childDevice.label = device_name;
log.info "Label Updated to [${device_name}]"
def hubiTools_validate_order(child, all) {
child.call(){
def order = [];
sensors.eachWithIndex {sensor, idx ->
order << settings["displayOrder_${sensor.id}"];
//if we are initialized and need to check
if(state.lastOrder && state.lastOrder[0]) {
def remains = all.findAll { !order.contains(it) }
def dupes = [];
order.each {ord ->
if(order.count(ord) > 1) dupes << ord;
if(state.lastOrder[idx] == order[idx] && dupes.contains(settings["displayOrder_${sensor.id}"])) {
settings["displayOrder_${sensor.id}"] = remains[0];
app.updateSetting("displayOrder_${sensor.id}", [value: remains[0], type: "enum"]);
remains.removeAt(0);
//reconstruct order
order = [];
state.lastOrder = order;
def hubiTools_rotating_colors(c){
ret = "#FFFFFF"
color = c % 13;
switch (color){
case 0: return hubiTools_get_color_code("RED"); break;
case 1: return hubiTools_get_color_code("GREEN"); break;
case 2: return hubiTools_get_color_code("BLUE"); break;
case 3: return hubiTools_get_color_code("MAROON"); break;
case 4: return hubiTools_get_color_code("YELLOW"); break;
case 5: return hubiTools_get_color_code("OLIVE"); break;
case 6: return hubiTools_get_color_code("AQUA"); break;
case 7: return hubiTools_get_color_code("LIME"); break;
case 8: return hubiTools_get_color_code("NAVY"); break;
case 9: return hubiTools_get_color_code("FUCHSIA"); break;
case 10: return hubiTools_get_color_code("PURPLE"); break;
case 11: return hubiTools_get_color_code("TEAL"); break;
case 12: return hubiTools_get_color_code("ORANGE"); break;
return ret;
def hubiTools_get_color_code(input_color){
new_color = input_color.toUpperCase();
switch (new_color){
case "WHITE" : return "#FFFFFF"; break;
case "SILVER" : return "#C0C0C0"; break;
case "GRAY" : return "#808080"; break;
case "BLACK" : return "#000000"; break;
case "RED" : return "#FF0000"; break;
case "MAROON" : return "#800000"; break;
case "YELLOW" : return "#FFFF00"; break;
case "OLIVE" : return "#808000"; break;
case "LIME" : return "#00FF00"; break;
case "GREEN" : return "#008000"; break;
case "AQUA" : return "#00FFFF"; break;
case "TEAL" : return "#008080"; break;
case "BLUE" : return "#0000FF"; break;
case "NAVY" : return "#000080"; break;
case "FUCHSIA" :return "#FF00FF"; break;
case "PURPLE" : return "#800080"; break;
def hubiTools_get_name_from_id(id, sensors){
def return_val = "Error"
if (id == sensor.id) {
return_val = sensor.displayName;
return return_val;
def hubiTools_get_order(order){
split_ = order.replace('"', '').replace('[', '').replace(']', '').replace("attribute_", "").split(',');
list_ = [];
split_.each{device->
sub_ = device.split('_');
list_ << [id: sub_[0], attribute:sub_[1]];
return list_;
def hubiTools_check_list(child, sensors, list_){
result = true;
count_ = 0;
id = sensor.id;
count_ ++;
result = result & inner_result;
//check for smaller
return (result & count_result);
*************************************************** END HELPER FUNCTIONS ******************************************************************
