Aussie
1
Hi all ... I am doing something wrong ... but I can't see what it is. I would appreciate some direction.
I have a global variable HubUpTimeDB.
In the Settings/Hub Variables dialog (screenshot below) I can see that HubUpTimeDB has a value of 1d, 11h, 1m, 16s ... so it seems to be being set OK.
In my rule action settings (screenshot below) I set the HUbUpTimeDB variable ... but on the Notify action the HubUpTimeDB variable shows as "null".
Why is HubUpTimeDB not showing the "correct" value?
I've never done this so I'm not sure - are your quotation marks correct?
In your second screenshot, "t" needs to be capitalized -- %HubUpTimeDB%
Aussie
4
Arrrrhhhhgggg ... Well I knew it has to be something stupid ... I should have seen that. App is 100% now. Thanks.
We've all done something similar before! Hard to see that sort of thing when you're that close to it.
system
Closed
6
