Hub Update 2.1.2
Hubitat Elevation Platform update 2.1.2 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.1.1:
Platform Additions / Changes
  • toDateTime(String dateTimeString) now accepts additional ISO8601 formats.
  • Added additional unsubscribe() methods.
  • Added new option for UDP messages to ignore response.
  • Added logging for UDP response timeout in live logs.
  • Added last will and testament options for MQTT client.
  • Added additional status messages for MQTT client (connected, disconnected)
  • Added logging for invalid App endpoint requests in live logs.
Drivers and Devices
  • New drivers:
    • RGBgenie Controller ZB-512x
    • Virtual Shade
    • Zooz Central Scene Switch (Zen21, Zen23 & Zen26)
    • Sinope TH1124ZB (4KW) Thermostat
    • Sinope TH1400ZB Thermostat
    • Sinope TH1300ZB Thermostat
    • Sinope load controller (RM3250ZB)
    • Sinope Moisture Sensor (WL4200 & WL4200S)
    • Sinope water valve (VA4200WZ)
    • Fortrezz MIMO2+
    • Fortrezz MIMOlite
    • Orbit 12-Station Sprinkler Controller (Basic valve control only)
    • Yale Conexis L1 Z-Wave Lock
  • New tested devices:
    • Aeotec ZW110-B09 switch using Aeotec Smart Switch 6.
    • Xfinity XHK1-TC keypad using Centralite keypad.
    • Xfinity XHK1-UE keypad using Centralite keypad.
  • New driver features:
    • Yeelight Integration: add mono bulb support.
    • Fibaro Wall Plug: add child device preference options.
New App Features
  • Rule Machine:
  • Motion Lighting: Added option to clear ‘Don’t Turn On After Manual Off’
  • Hubitat® Safety Monitor: Added play track for audio alert.
  • Dashboard clicking on green icon will refresh page (cloud only) to help update cached resources when dashboard has been saved to home screen on mobile devices.
Bug Fixes
  • Rule Machine:
    • Fixed Custom Attribute editing.
    • Fixed Scenes Per Mode.
    • Fixed Custom Attribute Trigger comparisons.
    • Fixed Button LED triggers.
  • Hubitat Safety Monitor: Removed button to Cancel Alerts during Pending Alert.
  • Fixed Generic Zigbee thermostat setpoint issues with Google Home integration.
  • Schlage Schlage BE468/BE469 Lock, added missing event decodes.
  • Fixed virtual fan controller cycle speed not working.
  • Mode Manager: Fixed bug with Earlier of Two Times.
  • Fixed issue with device discovery using only the label for first device discovered.
  • Fixed issue where device name in device details was shifting left.
  • Fixed issue with modes when app doesn’t use dynamic pages.
Release 2.1.2.115 Available
This hot fix release fixes the two bugs reported in Rule 4.0:
  • Presence trigger events now allow the correct choices.
  • Simple Conditional actions for a button device action now work as expected.
Release 2.1.2.117 Available
This hot fix release fixes the bugs reported in Rule 4.0:
  • Capture / Restore fixed.
  • Custom Action parameters that are zero now handled correctly.
  • Editing IF-THEN for Button Device fixed.
It also fixes the issue with Alexa saying a device is not responding when using the Amazon Echo App (not the skill).
Release 2.1.2.119 Available
This hot fix release fixes reported bugs in Rule 4.0 and Lock Code Manager, and a new feature for Notifier..
Rule 4.0:
  • Custom Actions parameters fixed to not throw errors.
  • Improved UI treatment for Edit of IF-THEN / ELSE-IF expressions.
  • Changed automatically created conditions, created from Trigger Events, to not use changed increased or decreased. Conditions will not be created for Trigger Events with increased or decreased, or for measurement devices that use changed, nor for Variable or Mode that use changed. For Trigger Events such as "Motion changed", the created condition will be "Motion active".
Lock Code Manager: Fixed app crashes when used with a large number of locks and/or user codes.
Notifications / Notifier: Now offers Play Track for audio notification on Music Player.
Release 2.1.2.123 Available
This hot fix release, probably the last one for 2.1.2, fixed reported bugs in Rule 4.0, Rule 3.0, Rule Machine, Button Controller 3.0, Motion Lighting, Notifier, Groups and Scenes, and Scene 1.2, as well as added two new feature to Rule 4.0:
Rule 4.0:
  • Fixed Wait for Certain Time having multiple Certain Times.
  • Fixed Wait for Certain Time scheduling and de-scheduling.
  • Fixed Wait for Variable for button devices actions.
  • Fixed In-Use-By information for global variables.
  • Fixed created conditions to not have a null value.
  • Fixed list of available scenes to not show null values.
  • Added Notes feature for rules.
  • Added Device Attribute value setting for variables, for numbers and strings.
Rule Machine and Rule 3.0: Fixed global variable use subscribe/unsubscribe.
Button Controller 3.0: Fixed capture/restore.
Motion Lighting: Fixed clearing of Don't Turn On if Turned Off Manually by mode change.
Notifier: Fixed bug in Play Track for audio notification.
Groups and Scenes and Scene 1.2: Fixed putting null values in list of available scenes.
Wait for Event Elapsed Time has a bug in this release. Will be corrected in the next release.
