Hub Update 2.0.4
Hubitat Elevation Platform update 2.0.4 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.0.3:
Platform Additions / Changes
  • Z-Wave device join improvements
Drivers and Devices
  • New drivers:
    • keyWe lock using keyWe Z-Wave Lock
    • August Pro Z-Wave Lock using August Pro Z-Wave Lock
  • New devices:
    • Schlage FE599 using Generic Z-Wave Lock
    • MCOHome z-wave dimmer switch using Generic Z-Wave Smart Dimmer
    • Leak Intel leakgopher valve using Generic Z-Wave Valve
  • New driver features:
    • Chromecast:
      • add queue for TTS messages (prevents truncation)
      • add stop after TTS preference setting
    • OpenWeatherMap:
      • Allow scheduling of refresh
      • Add option to specify coordinates
Bug Fixes
  • Zone Motion Controllers: fixed null error on first false motion activation.
  • Chromecast: fixed mute and volume state inconsistencies.
  • Properly parses Z-Wave AssociationGroupNameReport.
  • Properly parses Z-Wave Crc16Encap.
  • Rule Machine:
    • Fixed Before sunset and sunrise offsets. Note: Any rule with an offset before sunrise or sunset should be opened and Done hit to reschedule.
    • Fixed cancel on truth change.
  • Motion Lighting:
    • Fixed Don't Turn Off if Already On.
    • Fixed delay per mode.
  • Thermostat Scheduler:
    • Fixed modes setting setpoints and initialization.
    • Fixed manual hold sequence.
    • Fixed hold-off restoration sequence.
We have pushed out a hot fix release, 2.0.4.110. This corrects and issue with HSM that caused arm/disarm from mode changes not to work properly.
An additional hotfix, version 2.0.4.111 was released. This fixes the issue of the timezone not updating on the location page.
One more hotfix, version 2.0.4.113 was released. This corrects an issue that disabled many Simple Lighting instances from working properly. It also fixes the issue of Z-Wave failing to start in certain instances.
We have release version 2.0.4.116. This hot fix release deals with scheduling issues for offsets before sunrise or sunset in a number of apps, including Rule Machine, Simple Lighting, Mode Manager, and Thermostat Scheduler.
One more hot fix release, 2.0.4.117, is available. This further improves offsets from Sunrise or Sunset in Rule Machine, Mode Manager, and Thermostat Scheduler. It is not necessary to open any app to hit Done.
We pushed out 2.0.4.118. This fixes a small bug in Rule Machine. No need to open any app to hit Done.
