Hub Update 2.0.2
#1
Hubitat Elevation Platform update 2.0.2 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.0.1:
Platform Additions / Changes
  • app.updateSetting(): now creates setting if it doesn’t exist.
Drivers and Devices
  • New drivers:
    • Neo Coolcam Power Plug
    • Neo Coolcam Remote
    • Pioneer AVR (LAN ethernet)
  • New devices:
    • Iris V3 keypad (GreatStar) using Centralite Keypad
    • Ikea TRADFRI Outlet using Generic Zigbee Outlet
    • Salus SP600 Smart Plug using Generic Zigbee Outlet
    • Aeotec Garage Door Controller Gen 5 using Generic Z-Wave Garage Door Opener
    • Leviton DZ15S using Generic Z-Wave Smart Switch
    • Philips Hue White and Color Ambiance LightStrip using Generic Zigbee RGBW bulb
New Built-in App Features
  • Rule Machine
  • Thermostat Scheduler
    • Added Away setpoints for Days/Times schedule.
    • Add support for Rule Machine control (see this link).
  • Motion Lighting
    • Improved override to accept any dimmer change, not just physical switch.
  • Hubitat Safety Monitor
    • Custom Rule: Added disable switch to restrictions.
    • Added “armingAway” event to HSM Status.
  • Sharptools
    • Added pushable button support.
    • Added configurable logging.
Bug Fixes
  • Centralite Keypad: error on lock code encryption preference changes.
  • Fix double battery reports from Samsung 2018 sensors.
  • Generic Z-Wave Dimmer: Fix level reporting issues.
  • Generic Z-Wave Relay: Fix auto off disable not working.
  • Hue integration:
    • Terminate legacy polling job (incessant initialize logs).
    • Fix bridge linking settings being cleared.
    • Fix bridge ip address change not working.
  • Rule Machine:
    • Fixed bug where Stop would unschedule time settings.
    • Addressed race condition issue with quick events.
  • Hubitat Safety Monitor: Fixed bug with arming during delayed entry countdown.
[Solved] Generic Z-Wave Relay driver turns relay off when pressing on
[Solved] Any chance to turn off debug logs for Sharptools?
#2
A hotfix (build 108) has been released. It fixes a database error that some users were getting when authorizing 3rd party integrations.
#3
Rule Machine Issue with Periodic Triggers
There is a backwards compatibility break in the most recent release of Rule Machine involving Periodic Triggers. Any Triggers or Triggered Rules with Periodic will fail. To correct this problem, open the trigger and hit Done.
#4
We have released a hot fix (build 111). Fixes include the issue with Periodic Triggers from post just above. Also there is a fix for a bug with time inputs in Safari. There is also a fix for Motion Lighting: If you use the same button for more than one function in Motion Lighting, there was a chance of a race condition where one of the functions wouldn't be set (e.g. Turn Off with button and Disable On with Button, where exactly the same button is used for both). If you have any of these, you should open the instance and hit Done.
