I just saw the alert icon flagged tonight and when I looked at it, it said "hub is not registered, please register".
This is nonsense. I registered the hub to be able to install the 30+ devices weeks ago.
What happened.?
What happened.?
Sorry about that. If you could update the time from browser (Settings >> Hub Details) and then reboot the hub (also from Settings), the message will go away. Fix is coming in the next update.
I had this happen as well. You will find the Hubitat clock is not current. This happened on mine when the power was out for about 20 min. Go to settings, hub details and the time is at the bottom. Should be a button to refresh time using browser. I think it varies by ISP (I have ATT)
Took care of it. Thanks.
