After routine reboots to my hub for updates, 2 bulbs require a reboot to be functional again. It's a very minor issue that I don't mind doing, but I'm curious if there is a solution to this. None of the other bulbs I own have this behavior. The two impacted are Sengled E11-N13A (the extra bright ones). Other Sengled (normal brightness) bulbs don't do this.
Any ideas?
Anyone ever create an automation that tests all devices after a reboot or a change to confirm they respond? It would be nice to have a 'ping' test so I can go reboot offline devices.
Shut down the hub from the settings menu. Unplug power to the hub (at the wall not the hub) for 30 minutes. This will throw all your zigbee devices into panic mode. Power back up. They will establish more optimal routes over the course of the day. See if that helps you in the long run.
