Is it possible to change the email address associated with the hub registration?
Yes. @bobbyd can point you in the right direction.
You can do this on your own. There isn't way to change the e-mail address of an existing account, so what you'll need to do is create a new account, then use "Replace Admin" to supplant the old account with the new one. (I'm assuming that's your goal, or if it's a guest account, the admin will need to add this account and remove the other.) This process is described here:
Technically, your old account will still be hanging around after this, though it won't be usable for much unless you add it to another hub as an admin or guest. There is not currently any way to delete it yourself, so that would need a ticket, which you can submit here:
If none of this is your problem, like you acquired a used hub and the old user's registration is still present, they will have to un-register their hub from my.hubitat.com or use the above to switch it to your account.
Thank you for your direction, perfect.
