So far migration of my C-5 to C-7 using Hub Protect migrate is working fine.
Note: My C-7 IP address was not the same as my C-5.
Zigbee pairing challenges:
- Kwikset 916. Had to push the A button 8 times.
-Jasco ZB4101 - Had to hold the button down for 75 seconds to factory reset first for inclusion to work.
Link I used: Resetting a Jasco Z wave ZW-4101 plug-in wall outlet - YouTube
I did rediscover my Chromecast devices just to make sure.
Hubitat Elevation - Make sure to pick your new Hub device on your mobile device.
Had to disable and re-enable my Hubigraphs API to reconnect with the new IP.
Google Home (Mobile App) (Go to Settings -Works with Google)- Removed Hubitat and rediscovered my C-7.
Next- Re-add devices to the Google Home mobile app main screen. -
Hubitat settings (Location & Modes). Check your location name to make sure that is correct. Migration named my hub C-5(new).
Thank you Hubitat Team!!
