Changelog:
I'm not sure where you got the idea that this is how it works, did someone tell you this?
There is a process that runs every 24 hours in the background that calls the Hubitat servers, the message is approximately 100 bytes long and is json (it includes the current version you are running and your hub id). The server will respond with an empty json object if there is no update, or it will return a version number if there is one available. The version number is then stored in memory, that is how you get the little icon in the corner. This call also runs at startup (again, in the background) so if you reboot you'll see the message sooner than your normal 24 hour call.
It was an assumption. Apparently a bad one. But the reason why I made it is because it sometimes takes about 2-3 seconds after the whole page is loaded till the red notification appears. So the process, albeit totally local, does something what takes a lot of time now and then. That shouldn't happen if it's only 100bytes I think. Or am I wrong in this one too?
Besides that it doesn't really matter how it's done, the fact remains that it clearly messes with the total load time of the http call. And the point I was trying to make is that the http call isn't the best way to measure overall hub slowness.
That's the point of my post, there is never a call to our servers to check for an update when the page is loaded, it's already been done in the background.
Then we're back to the OP. Because if it's not the extra http load time, it must be something else and it still looks like it's related to the update.
I assure you it is not caused by the check for an update or an update being available.
I think what is happening here is an illusory correlation.
Ok, so if that is not the reason why some people have this problem it doesn't mean there is no problem. And by the way you are reacting now it come across as if you just don't care. What I just don't understand. I'm fine with you correcting my assumptions but the lack of helpfulness of the real issue is a bit disappointing.
Here's what happened: there was bad information presented in this thread and I attempted to correct it. The other option was to ignore it, but then I would still be accused of not caring, so it's a no win situation for me. I care very much about the slow down issue and I work with many of our customers everyday trying to figure it out. We do not post a lot of updates on the forum because there are not a lot of updates. I found an issue and fixed it in 2.1.9 and that was commented on in the release notes. I would appreciate any feedback about what I said that says to you I don't care. If I didn't care I would not have started this company.
It's not that you've said it in so many words. It's just the last post with the link to wikipedia was a little (don't know the English word for it) "cocky"?
Btw, this issue is in my opinion not related to the general slowdown issue.
Understood and removed. I want to maintain an open dialog, I think that's what separates us from our competition. Sometimes intent is very hard to discern via text. Recently someone made a comment about my mother and I had to ask them what they meant by it since my first instinct was that it was some kind of insult.
Thanks. Yeah, I would be very surprised if someone would have started about your mother. Assuming nobody here knows your mother.
Anyway, now that your here in this thread, any thoughts on the update slowness correlation some are experiencing? I've experienced it also. Twice. I think it was when I had to go from 2.1.5 to 2.1.6 or something. After that I've not had the problem anymore. But for others it still is an issue.
It's fictional. I've seen and done hundreds of updates. There is no slowdown that correlates in any way with an update being available.
Correlation does not equal causation...
Here is my hypothesis... Hubitat has acknowledged that they are working on correcting issue(s) that result in the hub slowing down over time. Maybe some sort of resource leak?
So.... if your hub is one that experiences a slow degradation of performance over time, then it may simply be coincidental that when your hub finally exhibits this behavior, that it coincides with a new firmware release.
Hubitat releases new firmware about once every month or two. So, if your hub’s performance degrades along this same timeline...the it is simply a coincidence.
Again, just a hypothesis.
Upgrade your hub to the latest. Take and record measurements.
Using Revert, go back a release. You’ll have an upgrade available almost Instantly. Take and record measurements.
You’d have the two test environments available in 5 or 6 minutes without having to wait for a 2am check.
Absolutely.. The hubitat staff actively participating in the community is wonderful.. So many companies put up a community forum and you never see official representatives..
Thank you everybody for your reactions.
@csteele, measurements are is the first couple of posts of this thread. And since I'm not having any slowdowns due to updates anymore (I do have the other slowdown issue though) I can make any new measurements.
@bruce, just because you haven't experienced this problem doesn't mean it's fictional. I can assure you it's pretty darn noticable if it happens. And it (at least for me) was instant from the moment I got that red notification on my screen. But maybe because you've never had the pleasure you can't fully understand why we are making this "correlation".
@ogiewon, true. And I have thought about it. But now that I have experienced the slowness myself I also realize it is totally different from the issue I'm this topic. Or there is a different cause, because this issue happens instantly and the other slowly digresses over time. So that's why I'm so persistent in pursuing this path.
But I'll leave it at this for now, because I don't have this issue myself at the moment and I have the feeling I'm only working on the defence here.
just grasping, im assuming there is a feed to HE servers, mabey HE servers are slowing slightly and (due to distance?) that is amplifying page loads/comunications.
You have shown a pattern its just a case of finding what it relates to..
Just a thought here.
I work daily with maintaining systems and keeping them stable for the municipality of Oslo in Norway. There we maintain several thousands virtual machines, huge storage solutions and several hundred different applications on both Linux and windows, in several datacenters and in the cloud.
It is in general very difficult to figure out what causes slowlyness from time to time. But, a tool that can maybe help out in finding root cause is called APM. Application Performance Monitoring tools from Dynatrace and AppDynamics digs very deep in almost any available source code out there. With a tool like this, even in Amazon Web Services, one can pretty quickly find out where the culprit is. Dynatrace has a tool that is well supported for Azure and AWS, called One Agent. Maybe that can help to monitor what is going on with the Hubitat cloud servers? I do not say that they are the culprit. Just want to be clear on this.
Another thought, what code is running on the HE operating system? If it is Java, one can propably also inject a APM agent onto the HE and you will probably find the source of the slowdowns pretty fast. These tools are quite amazing today, and is a great tool for developers to find where in the source code needs to be improved. These APM tools also can help monitor DB engines and dig deep in what is happening there. Memory leaks is also detected and reported, with history.
APM is a huge field these days, and most of the software houses out there have a demo version to try out first, casue they know how to charge the users for these tools...
I myselves do believe, based on exsperience, that memory leaks and bad source code with lack of error detection when something goes wrong towards DB calls, is the normal causes of slowdowns. DB locks is also seen often to be a reason, and usually solved by killing the DB calls that locks up DB. Other causes usually is lack of hardware resources(CPU/Slow IO to disks/WAN-LAN/Memory++), but the HE have more than enough of that, as far as I have read in other posts. Still reboots from time to time is set up on many systems, to actually keep them stable, so not so uncommon, really. But, the source of the casue takes some tools to figure out, for sure. With proper debugging tools it should be pretty easy to figure out. They pinpoint directly and show the time on each step in the code and can be set up to alarm when a threshold is breached, so pretty cool really.
Happy hunting
RogerThat
Oslo Norway
