Hub not showing in router after setting static IP
After a full day of fighting with a new router over various issues, I foolishly tried to set the static IP in the Hubitat hub. After I set the IP, the hub is no longer showing up in the router's client list. I did numerous reboots of the router and the hub. They are currently directly wired together. Do I need to do a full reset on the hub?
Do a Network Reset using the button on the bottom of the hub.
Thank you, you've made my night a little less miserable
You should set a reservation in your router for the hub. If you want to set a static ip, make sure you set the DNS (It can look like it's set but it really isn't). That likely is what was causing your issue.
Yeah, setting IP on the hub itself is not enough. Router needs to know there is a device with a fixed IP on the network to manage it properly.
