Hub migration from C7 to C8 and accessTokens
Hi, anyone know if the Apps accessTokens stays the same when using the migrate function to move from the C7 hub to C8-Pro?
My reason for asking is that I have several homebrewed systems that uses the accessToken to provide data into Hubitat, so I just want to know if I should be prepared to re-program all my devices, or if accessTokens also gets migrated.
If you use the migrate function they should all remain the same but a couple of cautions:
  1. Make sure you go into each of the apps and click Done
  2. Make sure you have the C7 turned off (or soft reset) or you'll get a conflict
Thank you for the answer, then I will give it a try this evening.
My cloud dashboard ids changed as did other ckoud apps.
Migration completed without a hitch, the only challenge I had was to convince my router of what IP address my new C8 should have. Once that was sorted all systems was up and running.
