I cannot seem to find a way to change/select the "Status attribute for Devices/Rooms" on the slave/remote hub - the selector is there, but there is no "Save" button. Changing out the master/host hub does not reflect across to the slave/remote.
Edit it from the device list with the pencil. I have successfully done this with many meshed devices.
WOW! That worked - THANK YOU!
Agree though it would be nice to allow edit of this preference on remote hubs.
@gopher.ny know all the preferences of a linked device are locked down since they should be set in the master hub but since this particular setting is per hub could a save button be added for this particular setting? Maybe similar to the same icon in Rule Machine?
