Minor nit, but apparently there is a difference in sort order between the originator hub and the recipient hub. First is from the originator.
Here is the recipient hub.
Because the name is different, it is sorting on the entire name include the "on HUB NAME" part.
Den comes before
Den 2
But
Den on.... comes AFTER
Den 2 ....
Duh
Problem solved. Just rename them on the recipient hub. Too bad we can't hide the device name.
On the device list, click the gear, then turn on compact view mode.
You da man!
