I have a GE/Jasco dimmer outlet and had it set to trigger a rule on "Physical off".
I had an Legacy Rule that wasn't working--so I created an identical RM-V rule app:
RM-V
RM-Legacy
With the Legacy App "X" disabled so only the RM-V app was active, I turned the light off physically:
I can see in the logs where that is detected (shows physical off in the logs and device events--but there's nothing in the logs indicating the RM app should be triggering.
I tried many times with both the legacy and the new RM app--I'm never able to make this rule trigger from the "physical off" event.
This is a mesh-connected device. On the hub it connects to directly:
And on the hub with the apps the mesh-device shows:
From the RM-V app/rule:
Thoughts?
Thanks!
