Hub Mesh on 2.3.3.121
Upgraded one hub and hub mesh while working is only showing + signs for devices that are available...aka not displaying correctly. When I updated a 2nd hub it was showing properly again. Examples:
On the not yet updated hub:
On the just updated hub:
So looking like either an error or you will need to update all hubs connected.
Can you PM me the hub id that it happened on? I'll check the engineering logs.
FWIW, I updated a secondary hub and left primary on previous and it appears to be working fine.
Hub mesh worked fine...but if I went on the not yet updated hub and tried to add something new from the already updated hub....it gave an odd display as shown above.
Download the Hubitat app
