Just looking at Hub Mesh tonight, have my C7 fully online and want to bring my C4 online since I just ordered an IoTaWatt. My goal is to use @ogiewon drivers on the C4.
A few questions...
Will I be able to hub mesh the power child devices from the C4 to the C7 where I have my Better Laundry Monitor app already configured for my Washer? I want to be able to add my Dryer monitoring here as well. My guess is the answer is Yes but I could also just install the app and create the rule on the C4 instead? Just thinking out loud on the best approach here.
Next, I have a Node Red Maker API on the C7 setup, Would it be better to setup Node-Red Maker API on the C4 as well and inject directly from the C4 instead of going to the C7 and injecting from there? I have both hubs setup to receive data within Node-Red.
Last, I want the mode to sync from the C7 to the C4. I have, on the C4, in Hub Mesh Settings " Follow another hub's mode changes:" set to the name of the C7. Mode Manager is not installed on the C4. Yet when I click Sync, the mode never changes?
