My AbraCadabra hubs are a little less magical than normal today... ![]()
I wanted to update the Status column info for several devices. Two are on the hub, the Leak Steam Generator Centralite is on another hub shared via Hub Mesh.
I can set the Status on the home hub for the device, but that isn't replicated on the hub it's shared to. You can open the drop-down on the hub where the device is shared to, but there's no Save so the setting doesn't work and the Status column stays empty.
C7, hub device is paired:
C8, hub the device is shared to:
@gopher.ny - I think this is your baby. ![]()
