Hello
Have a thought about how hub mesh communicates and how I should be able to make it work. I have two sites on different subnets that are linked by a wireguard tunnel. Both sides of the tunnel run pfsense and avahi to pass on mdns. Google cast, Amplifier, Nvidia Shield and Printer work and are properly reflected between the different subnets. But can not get the Hubitat hubs to find each other via hub mesh.
I have three Hubitat gateways. The two that are located within the same subnet find each other regardless of whether I select TCP or UDP as the setting via hub mesh. But the one on the remote site can not be found. One of the hubs is a C7 hub and I can see it using zeroconfServiceBrowser on
_sftp-ssh._tcp.
_ssh._tcp.
Does anyone have experience of how to make it work between different subnets and which protocol hub mesh works on?
