sgarzon
February 13, 2023, 8:44pm
1
Hi,
I am getting a Hub load is severe error, I found that my new phone and the Maker API app are not happy.
I updated the phone name, ip address, etc etc and updated all the apps where it was referenced.
I did some reading but it took me nowhere.
can anyone point me in the right direction on how to troubleshoot this?
Thanks,
Sam
Are you on the latest platform?
H_Local
February 13, 2023, 8:54pm
3
What version of firmware are you on? 2.3.4.1xx ? Is there an update available to 2.3.4.139 for you maybe?
Release 2.3.4.139 Available
Changes from 2.3.4.138
New devices
frient Smart Button
frient Panic Button
Develco Panic Button using frient Panic Button
New compatible devices
Third Reality Smart Plug (3RSP02028BZ) using Generic Zigbee Outlet
Eria Zigbee RGBW Bulb (AD-RGBW3001) using Advanced Zigbee RGBW Bulb
Onesti Products AS Touch Prolock using Generic ZigBee Lock
New App Features
Motion and Mode Lighting Apps made available again.
Bug Fixes
Fixed high CPU usage/memory leak under ce…
Bug Fixes
Fixed high CPU usage/memory leak under certain conditions.
sgarzon
February 13, 2023, 8:58pm
4
Thanks,
I am on 2.3.4.148.
I just noticed that the iphone wifi presence detector is not showing up.
It looks like you may be using something a bit more then the standard presence with the Hubitat app. Have you tried restarting your phone.
Is that a correct impression? If so what is the method you are using for managing presence between the phone and Hubiat.
sgarzon
February 13, 2023, 9:05pm
6
Yes, I just rebooted the phone and the hub, will let you know. THANKS!
sgarzon
February 13, 2023, 9:07pm
7
The hub reboot seems to have done it. strange because I rebooted it a few times while upgrading and soft reset.
thanks for your help,
Sam
system
Closed
February 13, 2024, 9:08pm
8
