Hello,
I have been having hub load issues since 2.3.7.137 thru 140..
Things I have tried are
(1) shutdown for 5 minutes and restart
(2) backup and immediate restore to fix any DB corruption
(3) Monitored over a period of few days ...
--  Logs - No errors
--  device stats (less than 5% , typically about 3%)
--  apps stats ( same as device stats... (less than 5% , typically about 3%)
(4) rebooting fixes it for some time.. but the elevated load returns
(5) DB Size is about 5-7
(6) after restart this is the CPU info
Date/time,Free OS,5m CPU avg
12-26 10:32:02,676132,1.71
12-26 10:37:02,359412,1.3
12-26 10:42:02,360020,0.53
12-26 10:47:02,357680,0.4
12-26 10:52:02,358180,0.26
12-26 10:57:02,358296,0.29
12-26 11:02:02,355976,0.29
12-26 11:07:02,355508,0.32
12-26 11:12:02,351220,0.4
12-26 11:17:02,351740,0.29
12-26 11:22:02,351932,0.24
12-26 11:27:02,351500,0.25
12-26 11:32:05,378664,0.2
12-26 11:37:05,370716,0.34
12-26 11:42:05,369020,0.25
12-26 11:47:05,369672,0.56
12-26 11:52:05,369252,0.57
12-26 11:57:05,366924,0.93
12-26 12:02:05,344888,1.26
12-26 12:07:05,344176,1.66
12-26 12:12:05,342336,1.49
12-26 12:17:05,342356,1.9
12-26 12:22:06,342256,1.82
12-26 12:27:06,339084,1.86
12-26 12:32:08,361432,1.95
As far as I know, the elevated load has been since the 2.3.7 update, 2.3.6 seemed to have been fine (based on the fact that the lights used to turn on faster than they do currently, just slightly but noticeable)
What else can I check to identify what is causing the elevated/severe load.
I have not restored to previous firmware, to be able to identify the issue, but will do it as a last resort to see if that fixes it !.. but would really like to find out the issue and then fix it rather than just revert the firmware
 waiting for the next message, the problem is I don' know if it is the platform update or the attempt to upgrade to the C8 and go back to the C5.
