I set up my first webCoRE piston using a linked motion sensor and dimmer switch from my existing SmartThings setup. The devices all appear in Hubitat, and the status of those devices gets updated when something happens on SmartThings.
However, when I try to control a device from Hubitat to SmartThings, the command seems to get lost along the way. In the Hubitat logs and device status, I see that the command ran, and the device state is updated in Hubitat (so as far as it knows, it happened), but there is no activity on the SmartThings side.
I set up Hub Link, and Send Hub Events, with the corresponding IPs for ST and Hubitat respectively.
Any ideas? I can provide screenshots or logs, if there is anything that can help.
