Just noticed I can't access either my C7 hub's cloud dashboard or remote access for a hub that I manage remotely. I'm pretty sure it is running 2.3.5.152 but I'm unable to verify this right now.
However I know the hub is live and with Internet connectivity as the InfluxDB-Logger instance continues to update a cloud instance of InfluxDB with new data, indicating automations are running:
I also have no issues accessing the router this hub is connected to via the TP-Link Tether app. The Remote Access service status is marked as operational on Hubitat's subscription support page:
I've since managed to confirm that automations are running (e.g. room lights) judging from the power logging done through InfluxDB-Logger. By inference, Zigbee radio is on and the house has power (hub, router etc. are on UPS).
List of things that are controllable remotely (behind the same router as Hubitat):
Blink cameras
Two WiFi eWeLink plugs I can use in an emergency to power cycle the hub and Blink sync module
TP-Link router remote management
List of things that aren't controllable remotely:
Remote Admin to HE C7 hub
HE cloud API links (e.g. cloud dashboard, MakerAPI)
I could try to power cycle the hub to see if that makes a difference, worst case being the hub fails to come back and that will cost me a 2.5 hour drive which I'd really like to avoid
Oddly, I had the same thing happen yesterday to my C-8 running 2.3.5.152. First time itโs ever happened. Was accessible by local dashboard link but not by WAN dashboard link and not by Remote Admin. My C-5 on same network, same firmware, was fine, and, like you, all my C-8 automations were working.
Yeah I'll eventually get around to trying that but since nothing seems to be broken other than my ability to remotely access the hub, I'd prefer to get the HE staff a chance to look at it, as this is not normal behaviour.
I do see both of my hubs there. But for the remote & inaccessible hub, the "Connect to Hub" button is disabled. "Hub Details" reveals the last checkin was at 2.17am.
The only problem with that is if you power cut the hub like that enough it will corrupt the database and you'll have to do a soft reset and restore. If you can set up a vpn that would be more ideal.
Im aware of that risk. This was why I am thinking of using a Kasa switch (with its cloud binding active) to signal the hub to reboot itself, e.g. an RM rule that checks if the switch is toggled 5 times in 5 seconds or something.
Yup gotta get it done at some point. Too many toys !
