Hub: C7
Version: 2.3.6.146
My hub has been crashing a frequently. Maybe once a week. Tonight upon power cycle, I received the database corrupt message. Did a soft reset and restore from most recent backup, and system seems to be working again.
I've been an adopter of the native homekit capability since it was in early beta. It always gets flaky and I see "device not responding" on all my devices in Apple Home. So I set the "reboot hourly" toggle, and it helps, but never solves the problem.
Alexa has also recently had a lot of trouble staying connected to the hub. It will tell me devices are not responding. Then an hour later will work fine.
I only run stock built-in drivers. I found community drivers to be unreliable over time. So really I expect the thing to be rock solid.
I see there is some way for Hubitat employees to see system logs. Could I enlist someone to check out my hub and see if there are anomolies?
