Have a custom app to do certain things. Wanting to add a reboot command in the app. I know I use 'http://IP:8080/hub/reboot.
Can't quite figure out how to implement the code for this. Someone give me a suggestion please.
void asynchttpPost(String callbackMethod = null, Map params, Map data = null)
void httpPost(String uri, String body, Closure closure)
void httpPost(Map params, Closure closure)
Well, that's what I looked at, but can't quite get the syntax right I guess.
Is it something like this:
httpPost( "192.168.1.171/hub/reboot")
Or do I need to separate things out?
Close, need to give it a place to analyze the response even if you do nothing, i.e.
if(security) cookie = getCookie()
httpPost(
uri: "http://192.168.1.171:8080",
path: "/hub/reboot",
headers:[
"Cookie": cookie
) { resp -> }
It was the response part that was tripping me up.
Thanks,
To follow up on this, I got it working using the code you suggested.
What I don't understand, Why do I need the cookie? I don't have security on the hub.
If I understand this code is using a map. Isn't there a way to just do a one line in the manner of:
No biggy, just trying to understand it.
Cookie is only needed if you have security enabled. As to the syntax, should be able to, I just have never coded it that way so no examples.
I tried this without the cookie stuff and it gave me an error. Tried leaving the headers part out and also got an error.
httpPost(
path: "/hub/shutdown",
headers:[
) { resp -> }
Tried this and got error:
httpPost("http://192.168.1.171:8080", "/hub/reboot") { resp -> }
Same with this:
httpPost("http://192.168.1.171:8080", "/hub/reboot", response())
I did create a routine called response.
And other variations on the same thing.
maybe
httpPost("http://192.168.1.171:8080", "/hub/reboot", httpResponse)
Closure httpResponse() {
NAH. Tried various different ways on the above and doesn't work.
Don't worry about it, it works ok the other way, so I'll use that.
Thanks for the time.
