Http put
It is any way I can call an API with the method PUT in the Rule Machine?
Not directly, as Rule Machine only has actions for GET and POST. However, you can do so with a custom app or driver, including this one:
You could also write a custom driver (or app/driver combo, if needed) directly for the device using similar methods, but something like this should get you started either way.
Thanks for the answer; I will go for the custom driver. With a little extra effort, I think I can make something useful for others with this api.
If interested, this is the driver :slight_smile:
