Hi, trying to set up a rule with a http GET to call webcore piston with following URL http://Hubitat_IP/apps/api/8/execute/:12eefec6c80a4d3b419376b9195af609:?access_token=b99e86-c2d9-414e-bdd6-461ffcf422d9&actionType=setComfort
Using the the same URL in Edge, Chrome works as charm but not from RM 5.1, I have tried to put actionType, access_token and piston into variables and changed the url to
http://Hubitat_IP/apps/api/8/execute/%piston%?access_token=%access_token%&actionType=%actionType% and this does not work eighter.
If you set a string variable to http://Hubitat_IP/apps/api/8/execute/%piston%?access_token=%access_token%&actionType=%actionType% does it look exactly the same as http://hubitat_ip/apps/api/8/execute/:12eefec6c80a4d3b419376b9195af609:?access_token=b99e86-c2d9-414e-bdd6-461ffcf422d9&actionType=setComfort, i.e. no extra spaces or missing characters.
Send GET to: http://Hubitat_IP/apps/api/8/execute/%piston%?access_token=%access_token%&actionType=%actionType%(http://Hubitat_IP/apps/api/8/execute/:12eefec6c80a4d3b419376b9195af609:?access_token=b99e86-c2d9-414e-bdd6-461ffcf422d9&actionType=setComfort)
I have enabled events, triggers and actions but no errors only action : with the same url executed.
Everytime a do a reguest from Edge, Chrome I can see the execution on the piston under Location Events, But running the action from RM they never turns up under Location Events.
When you are running from the browser you are using a different connection point for the send and receive, i.e. browser port 80 and hub port 80, when you send from the hub to itself you need to provide a secondary receive for the send.
Ahh, thank you so much also tried to running the http get without variables and that to works as charm. It was the only tiny thing as the "port" I would never figured out that one.
i have found similar in that if you send to a http address but the site is https, the request gets relayed to the https address but double-requests the request, ie http://www.url.com?abc=123
gets relayed to https://www.url.com?abc=123 but as https://www.url.com?abc=123&abc=123 which confuses the receiving script.
guess it depends on how the server reactes and redirects http requests to https
