Http Commands from another device to HE
Hi All,
Im wanting to use RTI as a front end, and wondering if there are a set of http commands that I can use to talk to HE from RTI eg. http://HubitatIPAddress:55501/KitchenOn
Any help would be much appreciated! would save me from writing a driver for RTI
The Hubitat Maker API built-in App allows simple http commands to query devices and issue commands.
any chance you can help with correct syntax for the commands?
http://HE IP address/apps/api/257/devices/65/off/?access_token= TOKEN - gives me the following error:
{"error":true,"type":"AppException","message":"Not Found"}
the commands list and details URL work fine, just not the explicit commands
Maker API has a section in the hub’s documentation pages that should help:
https://docs.hubitat.com/index.php?title=Maker_API
Are you sure that you've exposed device# 65 via the Maker API App?
What is returned if you issue the following command?
http://[hubIPaddress]/apps/api/257//devices/65/commands?access_token=[TOKEN]
Also, your syntax might be slightly off, try the following instead. Note that there is no "/" between "off" and "?access_token".
http://[hubIPaddress]/apps/api/257/devices/65/off?access_token=[TOKEN]
Great post. I’m going to try this. Did you ever have any luck? I have an RTI system and I’m
An RTI “programmer”.
Did you ever have success with this
